Raise Vehicle with Gas Shock Absorbers?
datsun
Post11-12-2004, 15:22    Subject: Raise Vehicle with Gas Shock Absorbers? Quote
Hello everyone,
I'm currently working on installing a sports suspension kit for my Datsun.
Could it be that installing gas pressure struts is the only way to raise the vehicle by 1-2 cm?
Previously, only oil pressure dampers were installed. The piston rod never had a tendency to extend. With the new ones, each damper lifts the car by about 20 kg.
Will this effect wear off?
Greetings.
Rainer.
Translated on 11-09-2026, 6:07.
Forenheini
Post11-12-2004, 16:54    Subject: Raise Vehicle with Gas Shock Absorbers? Quote
Yes, that's correct, and no, the effect doesn't diminish or only diminishes slightly.
Before I talk for too long... Click
Translated on 11-09-2026, 6:08.
No new posts Car Vacation Checklist: Essential Vehicle Prep General Tips
No new posts Document: MKB AKF, Vehicle vibrates Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, horn honks by itself Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3C: Raise Ride Height with Auto Leveling On-Board Diagnostics (OBD)
No new posts Shock Absorbers & Washers Transmission, Chassis, Body & Interior
No new posts Lowering a Golf IV T...just springs or also dampers (35mm)? Transmission, Chassis, Body & Interior
No new posts Replacing a used timing belt - Tension? Diesel Engine Technology
