solgie wrote: |
It is an AHU /Fault Log indicating:
01262 Magnetic Valve - Charging Pressure Limit / Interruption - Short to Ground
01265 Valve Exhaust Gas Recirculation //Interruption - Short Circuit to Ground
01269 Injector Start //Interruption - Short to Ground (Sounds good)
What have I done so far:
1. Resistance of all valves measured and compared with the specified values. OK.
2. Valve to PLC connection checked for continuity. OK.
3. When diagnosing a valve, these valves don't make a sound. |
All three actors are connected "to the other cable" together, drawing power from the 12V supply provided by relay 109.
If there is a lack of 12 V everywhere (due to a cable break, etc.), this, in my opinion, can explain all the problems with one cause -> look in this direction, or pull a temporary cable from the output of the 109 to one of the actuators. Maybe everything will work out again now . . .
