Auxiliary heater - activate ventilation EXTRA
butzel
Avatar-butzel
Post04-10-2002, 18:36    Subject: Auxiliary heater - activate ventilation EXTRA Quote
The Webasto Thermo Top is now finally installed. I'm now looking for a circuit that only turns on the ventilation system, which normally runs constantly and puts a strain on the battery, once the water has already reached a certain temperature (perhaps 40-50°?).
I haven't found a suitable temperature switch yet, and I don't want to use a bimetallic switch. It's too fussy for me.
I was already thinking about a circuit that, depending on the outside temperature, proportionally increases the fan speed icon_wink.gif (a power switch from the model airplane hobby...).
Has anyone tried this idea or something similar before?
Stefan.
Gruss
Stefan
Gremlin
Post05-10-2002, 17:18    Subject: Auxiliary heater - activate ventilation EXTRA Quote
Um...
My Thermo Top only activates the vehicle fan when the coolant reaches 30°C. Are you sure everything is wired correctly?
CU Gremlin.
butzel
Avatar-butzel
Post05-10-2002, 19:20    Subject: Turn on the Webasto. Quote
hello,
My heater used to be a supplementary heater. I've also tried connecting the cable that outputs the temperature signal, just for testing purposes. However, no signal is received icon_sad.gif.
Now I'm looking for an alternative.
Stefan.
Gruss
Stefan
Lucas
Post14-10-2002, 14:55    Subject: Auxiliary heater - activate ventilation EXTRA Quote
Just use a simple timer that turns on the fan after about 5 minutes. It can be easily built using an NE555 timer chip.
I control the speed of my fan continuously using a potentiometer with a PWM circuit. Here, you could also use a cheap NTC temperature sensor (e.g., from www.pollin.de) to control the fan...
Lucas.
No new posts Audi A4 B5 Ventilation Motors Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Lupo 6X1 MJ 2001: Ventilation Whistle Noise Fix Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts NSW: Switching Off! On-Board Diagnostics (OBD)
No new posts Golf TDI Manual: Specs, Review & More Diesel Engine Technology
No new posts Problems with ventilation and manual air conditioning Transmission, Chassis, Body & Interior
No new posts Gearbox Shortening: Smooth Shifting at 37k Miles Transmission, Chassis, Body & Interior
