Audi A3 Hydraulic Pump Problem - 1996
highspeed1
Post07-12-2004, 22:07    Subject: Audi A3 Hydraulic Pump Problem - 1996 Quote
"Hi, I've been having this problem for a long time where the ABS light won't turn off. The error code in the diagnostic memory says 'Hydraulic pump signal outside of tolerance.' I've now found a used pump that is 100% working, but I've heard from people that you need to read the old code from the ABS control unit and write it to the new ABS control unit. Is that true? How do you do that? Can it be done with VAG Com?"
Thank you.
P.S.: It's known that the fuses can oxidize, so I swapped them around, but the problem is still there. I'll buy some new ones and see if that fixes it.
Thank you.
Martin.
Translated on 29-08-2026, 10:41.
highspeed1
Post07-12-2004, 22:38    Subject: Audi A3 Hydraulic Pump Problem - 1996 Quote
"Or can you give me some tips on how to narrow down the problem? How can I check if the ABS hydraulic pump is working correctly? Or the control unit? I know that all the wheel sensors showed the same speed when checked with VAG COM."
Thank you.
Martin.
Translated on 29-08-2026, 10:43.
Post08-12-2004, 20:54    Subject: Audi A3 Hydraulic Pump Problem - 1996 Quote
Is there no option in the VAG-COM ABS unit to perform an output test? This would involve activating all actuators sequentially.
It might only be available in the full version.
Guste.
No new posts Error code 01276 - ABS hydraulic pump (V64) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem: Electronic Parking Brake (S-Tronic) in Audi A4, ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Problem with electricity. Auxiliary heater (G6 GTD) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 6N Hydraulic Pump Transmission, Chassis, Body & Interior
No new posts 01276 - ABS Hydraulic Pump V64 On-Board Diagnostics (OBD)
No new posts Glow plug problem Audi A4 TDI On-Board Diagnostics (OBD)
No new posts Audi A4 B7: 2.5 TDI Issue Above 2500 RPM Diesel Engine Technology
