30-11-2004, 12:27 Subject: Get Fit: Prepare for Your Big Trip! |
Hello fellow readers,
What do you think would be good to do for a 1-series BMW before a longer trip (approximately 4000 km in one week)? What should be checked or serviced?
Since my Spanish is quite limited, I don't feel like taking a course on how to use emergency spells.
- The oil is 7000 km old (5W-40 full synthetic).
- Checking other fluids is a given.
Unfortunately, I will probably have to use winter tires (with a smaller circumference).
Thank you for the tips.
Okay, please provide the German text you would like me to translate into English. I will only provide the translation. Transparency, Teamwork
Translated on 03-08-2026, 9:17.
Profile PM Garage |
Kusi
30-11-2004, 13:37 Subject: Get Fit: Prepare for Your Big Trip! |
If you are a member of the ADAC, they can also provide assistance in German.
Otherwise, bring plenty of music, and check the brake pads beforehand. 4,000 kilometers is quite a distance for a week, but it's doable.
Kusi.
Translated on 03-08-2026, 9:18.
Theresias Guest
30-11-2004, 15:07 Subject: Get Fit: Prepare for Your Big Trip! |
On my Russia tours, I usually get a service done beforehand. Otherwise, having a few liters of oil is also a good idea, and maybe a 5-liter canister of distilled water in case there's a problem with the radiator... you can fit quite a bit into a T4.
Oh yeah, 5-10 rolls of duct tape!
Otherwise, a multimeter and VAG-COM  .
Translated on 03-08-2026, 9:19.
Georg-TDI Guest
30-11-2004, 15:13 Subject: Get Fit: Prepare for Your Big Trip! |
If you have checked the following points, the trip should go smoothly without any foreseen problems.
- all liquids (regardless of quantity and age).
- Check brake and coolant hoses for leaks and porosity.
- You already have good oil in it, but still take 1 liter with you.
- Check brakes all around (material condition, ease of operation, possibly bleed).
- Torque specification for wheel bolts.
- Tire pressure appropriate for the journey.
- Wiper blades
- Check the battery (top up with distilled water due to potential 'overcharging').
- Warning triangle, first aid kit, towing rope, jump cables, flashlight, and possibly a tire sealant canister.
- A pair of spare light bulbs, fuses, and a piece of wire.
- Even with a navigation system, an atlas is still essential.
- ... maybe I forgot something  .
As a professional thief, you must have already checked everything, so nothing can go wrong.
Your car is already perfectly maintained, so just take the essentials (money, passports, and time), and you're ready to go!
Best regards, Georg.
Translated on 03-08-2026, 9:22.
Bee Guest
30-11-2004, 15:27 Subject: Get Fit: Prepare for Your Big Trip! |
In Spain, it is mandatory to have a reflective vest and two sets of replacement light bulbs. Not having them can be particularly expensive for foreigners.
Have a good trip! / Have a safe journey!
'Micha'
Translated on 03-08-2026, 9:24.
30-11-2004, 15:43 Subject: Get Fit: Prepare for Your Big Trip! |
- The VAG-COM software comes with  anyway, since the laptop already has navigation capabilities.
- Cleaning wipes?
That's over 40 euros!
I'd rather buy a new windshield wiper motor  .
- I already have a high-visibility vest because my life is too precious to risk.
- But what does "2 replacement light bulbs" mean?
4 x H4
4x H3
125903277x 21 Watts ????
Or these common phrases that claim to contain everything but often lack what you actually need?
Translated on 03-08-2026, 9:26.
Profile PM Garage |
30-11-2004, 16:32 Subject: Get Fit: Prepare for Your Big Trip! |
Here's what the ADAC says about the lights:
Quote: | It is recommended to carry a common 12-volt replacement bulb kit.
Okay, here's the translation:
"So, no 'obligation'."
Translated on 03-08-2026, 9:27.
Profile PM Garage |
gerbi Guest
30-11-2004, 17:09 Subject: Get Fit: Prepare for Your Big Trip! |
A 1N4148 diode for potential LMM failures certainly won't hurt and takes up very little space.
Translated on 03-08-2026, 9:28.
Julian Guest
30-11-2004, 17:12 Subject: Get Fit: Prepare for Your Big Trip! |
'So, no 'obligation'.'
Yes, in Spain, it is mandatory for foreigners to carry two warning triangles, one reflective vest, and an extra set of headlight bulbs (especially important with xenon headlights). These items are often checked.
Profile PM Garage |
joergs Guest
30-11-2004, 17:26 Subject: Get Fit: Prepare for Your Big Trip! |
Unfortunately, the ADAC is not always that competent. Contradictory statements on the website compared to what the hotline says are quite common.
Translated on 03-08-2026, 9:30.
Bee Guest
30-11-2004, 19:26 Subject: Get Fit: Prepare for Your Big Trip! |
'...and particularly interesting is the addition: '...mandatory for foreigners!' They apparently think that cars in Germany have 400V light bulbs  .
'Micha'
LZ Blaumann
Joined: 09/01/2003 Posts: 218 Karma: +6 / -0 Location: .at-Klbg.
30-11-2004, 20:22 Subject: Get Fit: Prepare for Your Big Trip! |
Have a good trip.
Spare tire pressure!!
Robert.
Translated on 03-08-2026, 9:31.
Gremlin Guest
30-11-2004, 21:39 Subject: Get Fit: Prepare for Your Big Trip! |
Then tell that quickly to the ADAC - because they don't say that to their members!!!
http://www.adac.de/ReiseService/Reise_Infos/Laenderinfos/default.asp?ComponentID=3428&SourcePageID=8000%230
-> Spain
-> important traffic regulations
Unfortunately, I am not a member; the link only works with registration  .
CU Gremlin.
30-11-2004, 22:03 Subject: Get Fit: Prepare for Your Big Trip! |
Okay, then just copy and paste.
Code: | Die Promillegrenze liegt bei 0,5.
Höchstgeschwindigkeiten in km/h:
Pkw/Motorräder Wohnmobile/ Gespanne mit
Gespanne mit Anh. üb. 0,75 t
Anh. bis 0,75 t
innerorts 50 50 50
außerorts 90 70 70
Schnellstraßen 100* 80* 80*
AB-ähnliche Straßen/
Autobahnen 120 90 80
* sowie auf Straßen mit mehr als einer Fahrspur in jeder Richtung
Diese Bestimmungen weichen von den in Deutschland gültigen ab:
Überholverbot besteht 100 m vor Kuppen sowie auf Sraßen, die nicht auf mindestens 200 m zu überblicken sind. Abschleppen durch Privatfahrzeuge ist verboten. Gelbe Linien (zick-zack oder unterbrochene) am Fahrbahnrand bedeuten Parkverbot.An blauen Markierungen ist das Parken zeitlich begrenzt,Beschilderung beachten!
Das Mitführen einer gängigen 12-Volt Ersatzglühlampenbox wird empfohlen.
Alle nach hinten über ein Fahrzeug hinausragenden Dachlasten und Ladungen müssen mit einer 50x50 cm großen rot-weiß diagonal schraffierten Warntafel gekennzeichnet sein. Diese ist im Kfz-Zubehör-Handel erhältlich.
Telefonieren mit Freisprecheinrichtung während der Fahrt ist erlaubt, die Verwendung von Head-Sets und Ähnlichem hingegen verboten.
Verkehrsverstöße, insbesondere Geschwindigkeitsüberschreitungen und Alkoholdelikte, werden mit hohen Geldbußen geahndet.
Das Tragen einer reflektierenden Warnweste beim Verlassen des Fahrzeuges im Falle einer Panne oder eines Unfall auf Autobahnen und Landstraßen ist vorgeschrieben. Aus Sicherheitsgründen und zur Vermeidung von Bußgeldern sollte sie stets griffbereit sein.
Besondere Verkehrsschilder: Alto = Halt; Atencion, Cuidado = Achtung, Vorsicht; Viraje peligroso = gefährliche Kurve; Ceda al paso = Vorfahrt beachten; Paso prohibido = Durchfahrt verboten; Prohibido aparcar = Parkverbot; Llevar la derecha (izquierda) = rechts (links) fahren. | Transparency, Teamwork
Translated on 03-08-2026, 9:32.
Profile PM Garage |
Zoidberg Blaumann
30-11-2004, 23:14 Subject: Get Fit: Prepare for Your Big Trip! |
What's missing from the ADAC listing: In Spain, private towing is also prohibited!
Otherwise, I have nothing to add to the previous recommendations. After all, diesel engines are designed for long distances – they're happy when they get to run a few thousand kilometers without being turned off  .
I drove from Portugal to Germany myself in October, and before the trip, I checked the oil, air pressure, and water levels, but didn't do anything else major. If you, which I doubt, mostly drive the car on short trips, it would be a good idea to check the oil level after driving a few hundred kilometers on the highway.
Otherwise, have a good trip!
Bye.
Christoph.
Translated on 03-08-2026, 9:33.
