Bastelfred Blaumann
Joined: 01/09/2004 Posts: 51 Karma: +6 / -4 Location: bei Schwerin
06-08-2007, 11:42 Subject: Replace intake manifold pressure sensor in the control unit? |
Can the intake manifold pressure sensor be replaced in the engine control unit (ECU) of an AFN engine? I have a part number from Bosch: 0 273 003 210, which is supposed to be a BOSCH 250 kPa MAP sensor. Is it essentially the same as the one in the ECU of the AFN engine? Can someone tell me something about it?
I'm having a problem where my device occasionally throws a "short circuit" error code.
Thomas Profi-Schrauber
Joined: 04/17/2002 Posts: 329 Karma: +2 / -0 Location: Darmstadt
07-08-2007, 12:57 Subject: Replace intake manifold pressure sensor in the control unit? |
Yes, that is the correct MAP sensor.
You should be able to easily exchange it.
Thomas. -----------------------------------------------------
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
vagtuning Guest
08-08-2007, 22:24 Subject: Replace intake manifold pressure sensor in the control unit? |
Does Bosch supply this as a replacement part?
And does VW/Ford only sell complete steering control units?
Bastelfred Blaumann
10-08-2007, 10:22 Subject: Replace intake manifold pressure sensor in the control unit? |
Is it also available on eBay?
[EBucht Link]
Joined: 04/12/2002 Posts: 18113 Karma: +800 / -0 Location: St.Gallen 2018 Volkswagen T6
10-08-2007, 12:15 Subject: Replace intake manifold pressure sensor in the control unit? |
... or here:
Okay, I will translate the text from the provided URL. However, I need the actual text content from that URL to perform the translation. Please provide the text from the webpage located at http://shop.dieselschrauber.de/product_info.php/products_id/291. Once you provide the text, I will give you the English translation.
Profile PM WWW Garage |
Bastelfred Blaumann
13-08-2007, 10:48 Subject: Replace intake manifold pressure sensor in the control unit? |
You could have mentioned that earlier. I ended up buying it somewhere else.
13-08-2007, 10:59 Subject: Replace intake manifold pressure sensor in the control unit? |
*g* You didn't ask me, but no worries, thanks for checking! Since I didn't think there would be a market for it, I didn't include it in the shop.
neubaupe Guest
13-08-2007, 11:09 Subject: Replace intake manifold pressure sensor in the control unit? |
Hi!
Even though it probably doesn't happen very often, what do you do if you want to run an Audi, BMW, or Mercedes (AFN) engine with a turbocharger pressure exceeding 1.5 bar?
Best regards.
Peter.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2403 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
13-08-2007, 11:18 Subject: Replace intake manifold pressure sensor in the control unit? |
neubaupe wrote: | | ...what do you do if you want to run an AFN with a boost pressure above 1.5 bar |
Mount the 300kPa sensor and adjust the sensor characteristic curve accordingly. (But don't ask me for details, I'm afraid I'm not that familiar with the subject).
However, a significant number of adjustments would need to be made, both mechanically and in terms of software, for pressures exceeding 1.5 bar to be meaningful in the AFN system.
Guste.
Profile PM Garage |
