dokatoto Guest
07-08-2007, 5:27 Subject: Engine Crankshaft Position Sensor, V6 2.5 TDI AKN Engine |
Which pistons need to be at the top when the crankshaft is oriented horizontally, and what is the cylinder firing order?
I can't seem to find the darn locking hole anywhere...?!
The engine can only be rotated a little bit before it stalls, which means the 'OT' (Overtime) position is not correct after the camshaft replacement...
Thank you and best regards.
Toto
christians Profi-Schrauber
07-08-2007, 11:32 Subject: Engine Crankshaft Position Sensor, V6 2.5 TDI AKN Engine |
During the initial installation, the 1st cylinder is the furthest forward in the direction of travel, on the right side. Count as: if in the text above = vehicle in front:
4 1
5 2
6 3
Ignition Sequence: 1-4-3-6-2-5
Gruß Christian
myfisch Guest
07-08-2007, 11:34 Subject: Engine Crankshaft Position Sensor, V6 2.5 TDI AKN Engine |
Without the locking pin, the repair seems quite daring, isn't it?
Christian is right!
Greetings
dokatoto Guest
07-08-2007, 13:01 Subject: Engine Crankshaft Position Sensor, V6 2.5 TDI AKN Engine |
I have the locking pin! But even with a pencil and ruler, the motor can only rotate a few degrees in both directions before it gets stuck...?!
Now I will remove the cams again, then the valves will be closed, in order to check whether the crankshaft is rotating freely.
and I have to find the hole again....
cksIT Blaumann
Joined: 05/22/2004 Posts: 399 Karma: +18 / -0 Location: Riedstadt
07-08-2007, 15:17 Subject: Engine Crankshaft Position Sensor, V6 2.5 TDI AKN Engine |
What does "a few degrees" even mean? He shouldn't be able to turn at all anymore... (there's still some play, but only minimal).
dokatoto Guest
09-08-2007, 6:17 Subject: Engine Crankshaft Position Sensor, V6 2.5 TDI AKN Engine |
So, to clarify the issue: I don't know where I inserted the screw... anyway, not into the correct hole.
Now I've taken everything apart again, and lo and behold; I've found the hole, and now everything fits perfectly again.
