Parking Heater Smoking: Troubleshooting & Fixes
tdi-seppl
Post11-01-2005, 17:42    Subject: Parking Heater Smoking: Troubleshooting & Fixes Quote
My Termo Top Diesel, manufactured in 1995, smokes heavily when I start it, to the point where it looks like the whole car is on fire. It also struggles to start. Once it's running, the smoking stops after about 5 minutes. What could be the cause? Does anyone have a repair manual for this kind of issue? I would appreciate it.
Hi TDI-Seppl,
Baust Du Turbo an Diesel,läuft Diesel wie Wiesel
Translated on 18-09-2026, 1:52.
christians
Post11-01-2005, 23:35    Subject: Parking Heater Smoking: Troubleshooting & Fixes Quote
First, the usual disclaimer regarding the diagnosis, as far as it was already implemented in version 95.
Most likely, first, the heating system is completely full of soot and ash internally, and second, the filter material is worn out, which means a new combustion chamber is needed. The work itself is simple; it's just a matter of opening it up and screwing things together. The screws are T15, and one of them is located a bit deeper.
Gruß Christian
Translated on 18-09-2026, 1:53.
Klausel
Post12-01-2005, 1:04    Subject: Parking Heater Smoking: Troubleshooting & Fixes Quote
Hello!
If the smoking is accompanied by even a very slight loss of coolant, then there is also a...
Undichtigkeit möglich - so wars zumindest bei meiner Thermo Top T. With utmost precision.
"Hinsehen" was also a drop to be recognized. The burner apparently transformed...
The water that had seeped in turned into enormous amounts of smoke.
At the repair shop, they tried (unsuccessfully) to fix it with a new set of seals.
Good luck.
Klaus.
Translated on 18-09-2026, 1:54.
gwg
Post12-01-2005, 1:16    Subject: Parking Heater Smoking: Troubleshooting & Fixes Quote
I had a Webasto auxiliary heater installed in a Volvo 265 DL many years ago.
It was leaking; the antifreeze in the coolant was smoking excessively!
Water only creates 'steam.'
Günther.
Translated on 18-09-2026, 1:55.
tdi-seppl
Post12-01-2005, 20:47    Subject: Parking Heater Smoking: Troubleshooting & Fixes Quote
Thank you for the answers.
"My auxiliary heater isn't yet diagnosed, but it's producing white smoke, although there's no water leaking. It smells strongly of diesel. The heater also starts very poorly, and when it does start, it produces the aforementioned smoke. Where can I get a new combustion chamber?"
Translated on 18-09-2026, 1:56.
tdi-seppl
Post14-01-2005, 18:48    Subject: Parking Heater Smoking: Troubleshooting & Fixes Quote
hello,
Combustion chamber defective.
Can someone explain how to install a new burner chamber? What needs to be disassembled?
termo top dw 50
I would be happy! / I would appreciate it! / I would be delighted!
Translated on 18-09-2026, 1:57.
No new posts Power steering is making a loud noise / sucking in air / ... General Tips
No new posts Install Parking Heater in VW Passat 3BG Troubleshooting & Guides
No new posts VW T4 AHY: Defective Auxiliary Heater / Parking Heater Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7: Limp Mode & Smoke - Troubleshooting Diesel Engine Technology
No new posts Blue smoke from turbo when cold Diesel Engine Technology
No new posts DPF Smoke: Passat 3C Engine Revving Issues Diesel Engine Technology
No new posts TDI VW Golf 3: Smoking Exhaust & Overheating Issues Diesel Engine Technology
