All doorknobs are unlocked - lock won't open
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
Klausel
Post23-01-2005, 14:49    Subject: All doorknobs are unlocked - lock won't open Quote
Hello!
I have read all the threads about driver's and passenger doors that are no longer opening. "None of them quite fit my problem."
Currently, with moderate frost (4-door car, central locking with remote control), this is what I'm experiencing:
(1) All the door handles move smoothly upwards (!).
(2) Driver's door cannot be opened: The exterior door handle moves outward without resistance, all the way to its stop (as if the door were locked).
(3) (Entering the car through the passenger door): Same attempt using the interior door handle: same result.
(4) Locking and unlocking with a remote or key does not make a difference.
(5) After a few minutes, everything is back to normal.
The phenomenon sometimes occurs in exactly the same way with the front passenger door as well.
If I haven't misread, similar door problems to those previously described have occurred.
Do not turn on the door knob when it is already in the "on" position.
Where do I need to go?
Regards, Klaus.
Please provide the text you would like me to translate from German to English.
Volkswagen Golf III, AFN engine, 1997, 140,000 kilometers.
Zoidberg
Post23-01-2005, 18:11    Subject: All doorknobs are unlocked - lock won't open Quote
That must be really frustrating, having your door lock frozen. G3 is likely the same lock as the one on the 35i Passat, and I had the same problem with it just before Christmas.
The solution is to remove the lock mechanism – it's quite simple and doesn't even require removing the door panel. verschandeln it thoroughly, then re-grease and oil it. Then it should work properly again.
greetings
Christoph.
golfschrauber1981
Post23-01-2005, 19:04    Subject: All doorknobs are unlocked - lock won't open Quote
I would also suspect a frozen lock.
I experienced the same problem with my G3 at the beginning of December.
I simply sprayed a generous amount of WD-40 into the locking mechanism, and I haven't had any problems since.
LZ
Post24-01-2005, 22:35    Subject: All doorknobs are unlocked - lock won't open Quote
"I know that problem, I had it last winter too. I initially thought it might be frozen seals, but it wasn't. The window frames could be lifted. Then I removed the handles – there's a Torx screw in the groove – and I flooded the lock mechanism with Innotech Power Grease." Since then, it's been quiet.
Best regards, Robert.
No new posts Roomster Tailgate Won't Open: Remote Button Issue Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 Door Auto Open/Close Problem (8L) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF not regenerating Troubleshooting & Guides
No new posts LMM-Sollwert nach oben setzen nicht möglich Diesel Engine Technology
No new posts Adaption Kanal 4 geht nicht! Alle anderen schon, wieso? On-Board Diagnostics (OBD)
No new posts ZV öffnet die hinteren Türen nicht Electrical Systems, Vehicle Electronics, Multimedia
No new posts A3 8P: Komfort-STG - ZV öffnet nicht mit Schlüssel On-Board Diagnostics (OBD)
