Turbocharger: High Boost Pressure Causes Failure?
1Z-Treiber
Post30-01-2005, 17:37    Subject: Turbocharger: High Boost Pressure Causes Failure? Quote
I have a GT17 turbocharger lying around, and there's a note attached that says the boost pressure is too high. What's wrong with it? Or can I just install it and enjoy more power? (I doubt it.)
Translated on 08-09-2026, 2:04.
Post30-01-2005, 18:45    Subject: Turbocharger: High Boost Pressure - Defect? Quote
1Z-Treiber wrote:
I have a GT17 turbocharger lying around, and there's a note attached that says the boost pressure is too high... what's wrong with this thing? Or can you just install it and enjoy more power? (I doubt it)
If it was replaced by a "normal" workshop, there's a relatively good chance that it's not defective.
Your question "Does a larger turbocharger mean more power?" indicates that you don't fully understand the principles of turbocharger control and/or power control, or mixture formation in diesel engines. You can fill this knowledge gap by reading the correct technical articles, for example, here.
No, I'm not going to give you a link right now.
Translated on 08-09-2026, 2:05.
1Z-Treiber
Post30-01-2005, 21:48    Subject: Turbocharger: High Boost Pressure Causes Failure? Quote
Well, it's clear that you can't achieve much with just the charger alone, but still, thanks for the reply...
Yes, it was installed by a 'regular' workshop. Is there a way to test if it still works (while it's installed)? Probably not, right?
Don't jump to conclusions and start attacking people for asking a seemingly simple question.
Translated on 08-09-2026, 2:07.
donalexo
Post30-01-2005, 22:50    Subject: Turbocharger: High Boost Pressure Causes Failure? Quote
@1Z driver:
Please feed the SEARCH function with the following terms:
- Stuck VTG (Variable Torque Gear)
- VTG adjustment
- make VTG usable.
- Intake manifold pressure, control differential.
You'll be bombarded with posts!
I suspect the turbo was discontinued for that reason. With a little technical skill, you can disassemble it, clean the VTG mechanism, and you'll likely enjoy working on it, as long as you have a suitable engine to install it in.
It's not suitable for the 1Z because it has a wastegate turbocharger.
Alex.
Touran 1.9 TDI, EZ 09/2004
Translated on 08-09-2026, 2:08.
1Z-Treiber
Post30-01-2005, 22:52    Subject: Turbocharger: High Boost Pressure Causes Failure? Quote
ok danke,
Sure, it's not meant to fit on my 1Z.
Translated on 08-09-2026, 2:09.
No new posts Audi A3 (8L): High Mileage Issues Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: High oil consumption, AFB and AKN engines Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter, Year 2012/2013, High Standby Current Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts High Boost Pressure BKD: Causes & Solutions Diesel Engine Technology
No new posts High Boost Pressure VTG TDI Diesel Engine Technology
No new posts High boost pressure causing ALH error code 17965, log Upload
No new posts Turbocharger Failure? AFN Engine Problems Diesel Engine Technology
