Wheel Alignment After Lowering Suspension
hollari
Post28-12-2005, 21:45    Subject: Wheel Alignment After Lowering Suspension Quote
I've already tried using the search function quite a bit, perhaps not enough.
But somehow, I've been searching for an answer for a long time.
Therefore, I'll simply ask the question:
Who here has actually had their car lowered (I'm talking about...)?
(a modification to a 20mm lower suspension system to make the car safer).
Then have the alignment adjusted (I'm talking about doing this 5-8 times).
and the car is still much worse than it was before?
Specifically, it's about a VW Vento TDI. (Sorry, that word had to be included.)
The back of the sofa (which I bought used) had already sunk in a lot, so I had to do something about it.
What can be done? -> Subjunctive clause.
Word from my trusted mechanic:
'I've sold this many times before, so it must be good!'
Said and done -> everything installed; adjusted the suspension for the technical inspection -> instead of 11 cm of ground clearance, there are only 8.4 cm!
-> Reassembled with original springs (the dampers were defective and needed to be replaced).
For verification purposes -> everything is okay.
A few months later -> replace the front rubber control arm bushings!
You probably think it's no big deal.
That's not the case;
Bolts are rusted -> new engine support (front axle).
-> exchanged
-> It works quite well for a while (2 months).
-> The car is driving worse and worse again.
-> Adjust tracking.
-> The car drives very well.
-> 4 months later ->-> The car is driving poorly again (gradually worsening).
I think I'm going to throw that monstrosity away.
Does anyone have any ideas on how I can check the track myself?
I need the exact parameters (angles).
which I can easily measure using simple methods.
Translated on 27-07-2026, 21:27.
No new posts Lowering with VCDS: Electronic Ride Height Calibration Troubleshooting & Guides
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Wheel Alignment: High Tracking Angle Deviation? Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Lowering approval (ABE) Transmission, Chassis, Body & Interior
This topic is locked, you cannot edit or reply. Suspension and Shock Absorbers Transmission, Chassis, Body & Interior
No new posts Wheel Alignment: Get Accurate Results Now! Transmission, Chassis, Body & Interior
