bollock Guest
14-02-2005, 9:28 Subject: Explosion Diagram for VE 4 - Search |
Hello!
I want to seal the ESP (Electronic Stability Program) on my Golf 1.9 TD.
'Does anyone happen to have an exploded diagram of the part, so I can identify the individual components BEFORE I start scattering them all over the workbench?'
Sure, here's the translation:
'I would appreciate it!'
Thank you, Martin.
Translated on 07-10-2026, 9:58.
14-02-2005, 9:47 Subject: Explosion Diagram for VE 4 - Search |
"Something like that?" or "Is that what you mean?"
| Description: |
 Download |
| File name: |
VP.pdf |
| File size: |
205.81 KB |
| Downloaded: |
970 times |
Translated on 07-10-2026, 9:59.
Profile PM Garage |
bollock Guest
14-02-2005, 9:53 Subject: Explosion Diagram for VE 4 - Search |
Okay, thank you!
That's exactly what I was looking for.
Thank you very much!
Best regards, Martin.
Jockel Blaumann
Joined: 03/14/2004 Posts: 249 Karma: +15 / -1 Location: 84478 Waldkraiburg
14-02-2005, 13:10 Subject: Explosion Diagram for VE 4 - Search |
Enjoy your meal!
Here are a few tips:
The part where the throttle cable is attached is on the shaft that goes through the pump cover.
attached to a toothed coupling, make sure to note how the parts were assembled, when...
If the part is installed incorrectly, the engine will either not run at all or will run with excessive throttle.
If you also want to remove the high-pressure part, then secure the pump with the high-pressure attachment.
Secure the part in a vise from above, otherwise the individual components will fall out, especially the rollers.
on which the thrust bearing sits, or the disc that is located beneath the piston foot.
Loosen the screws on the high-pressure part in a criss-cross pattern, and avoid wedging it when removing it.
If you remove the feed screw, make sure to note exactly how far it was inserted.
Otherwise, you'll keep waiting forever.
Pay meticulous attention to cleanliness in all work.
Have fun, bye, Jockel.
"Neu": Bora Variant, ASV
Translated on 07-10-2026, 10:00.
Profile PM Email |
