dj1 Guest
18-02-2005, 12:47 Subject: Valve Hole Diameter: Find Your Rim Size Here |
What is the diameter of the hole in the rim for the valve?
Can someone please measure a rim using a caliper?
Thank you.
DJ.
Translated on 31-08-2026, 14:15.
dj1 Guest
18-02-2005, 23:06 Subject: History: The Story Behind... |
Perhaps I'll briefly explain the background.
I bought new rims.
I also bought valves from Raid at the same time.
Problem:
The valves have a diameter of 10.65 mm.
However, the hole in the rim (for the valve) is only 8 mm in diameter.
Question: Can I simply enlarge the hole with an 11mm drill bit so that the valves fit?
Nothing should really go wrong if I try to maintain a reasonable angle.
Thank you for your tips.
DJ.
Translated on 31-08-2026, 14:16.
Günther Guest
19-02-2005, 0:00 Subject: Valve Hole Diameter: Find Your Rim Size Here |
I wouldn't do that!
The valves are 'pulled in' during the 'installation' process, which makes them thinner.
Günther.
Translated on 31-08-2026, 14:17.
dj1 Guest
19-02-2005, 12:38 Subject: Valve Hole Diameter: Find Your Rim Size Here |
These are Raid's metal valves!
It doesn't pull it in  .
I only need to drill from 8mm to 11mm - what's the problem with that?
I have aluminum drill bits, and the rim is also made of aluminum.
I don't understand why my wheel doesn't have a standard diameter.
I am grateful for any advice!
DJ.
Translated on 31-08-2026, 14:18.
Joined: 04/12/2002 Posts: 18139 Karma: +805 / -0 Location: St.Gallen 2018 Volkswagen T6
19-02-2005, 12:50 Subject: Valve Hole Diameter: Find Your Rim Size Here |
Okay, then there's nothing against drilling it out. How do the valves seal? Is there a rubber ring behind them?
Translated on 31-08-2026, 14:19.
Profile PM WWW Garage |
Bertil Profi-Schrauber
19-02-2005, 13:22 Subject: Rim Hole Size for Ve: Find the Diameter |
dj1 wrote: | What is the diameter of the hole in the rim for the valve?
8mmGruß Bertil
Günther Guest
19-02-2005, 13:28 Subject: Valve Hole Diameter: Find Your Rim Size Here |
DJ
Your rim likely has the standard bore for the 'standard valve'; what 'advantage' do your metal valves offer?
Günther.
Translated on 31-08-2026, 14:20.
dj1 Guest
19-02-2005, 14:38 Subject: Valve Hole Diameter: Find Your Rim Size Here |
So, my valves have rubber seals at the top and bottom, so they should be airtight.
Here's a link to those things:
http://cgi.ebay.de/ws/eBayISAPI.dll?ViewItem&category=14771&item=7953912575&rd=1&ssPageName=WDVW
Advantages of valves:
I have a polished bed, so I want flat valves.
It's strange that the valves then wouldn't have standard sizes!
DJ.
Translated on 31-08-2026, 14:22.
dj1 Guest
19-02-2005, 14:39 Subject: Valve Hole Diameter: Find Your Rim Size Here |
Günther
Translated on 31-08-2026, 14:23.
Günther Guest
19-02-2005, 15:19 Subject: Valve Hole Diameter: Find Your Rim Size Here |
However, to inflate it, you will need an adapter that is compatible with the valve.
Otherwise, drill carefully.
Günther.
19-02-2005, 15:27 Subject: Valve Hole Diameter: Find Your Rim Size Here |
Caution!! These products did not previously have approval for use in the StVZo regulations. Gruß Bertil
Translated on 31-08-2026, 14:24.
dj1 Guest
20-02-2005, 13:12 Subject: Valve Hole Diameter: Find Your Rim Size Here |
It's strange that Raid isn't adhering to the standards, or what kind of rims are these valves intended for?
An adapter for filling was included.
DJ.
20-02-2005, 14:15 Subject: Valve Hole Diameter: Find Your Rim Size Here |
dj1 wrote: | ... which rims are these valves for?
"I'm familiar with these valves from motorsports. They are used in various types of rims. These valves are only a few grams lighter and are less susceptible to centrifugal forces."
Please be aware that drilling the valve opening in your rims will void their approval. Therefore, these valves are also non-standard, so they won't fit on standard road rims without modifications. Gruß Bertil
Translated on 31-08-2026, 14:25.
ThomasB Guest
20-02-2005, 15:32 Subject: Valve Hole Diameter: Find Your Rim Size Here |
I also have 'hidden' valves installed. And I don't believe that my tire dealer would install non-approved products, let alone drill holes in the rims.
http://www.turbotommi.de/bremse2.htm
Thomas
Translated on 31-08-2026, 14:26.
dj1 Guest
20-02-2005, 20:54 Subject: Valve Hole Diameter: Find Your Rim Size Here |
@ Thomas B
Where did you get your 'hidden' valves from?
Link?
Does anyone know of any other places where I can buy 'hidden' valves that will fit (8mm)?
DJ.
PS: Man, it's so complicated to just find 4 small valves.
Translated on 31-08-2026, 14:27.
ThomasB Guest
20-02-2005, 21:25 Subject: Valve Hole Diameter: Find Your Rim Size Here |
I'll check tomorrow to see which manufacturer my [items] are from.
Thomas
