AFN, spark plug, stripped threads, help!!!
qwert1
Karma-Bildequivalent
Karma: +6 / -24   Thank you, like it!
Post03-03-2005, 18:36    Subject: AFN, spark plug, stripped threads, help!!! Quote
hello,
I wanted to change the spark plugs today, but the fourth one got stuck, even though I could turn it. I can't get it out anymore. icon_evil.gif Do I have to remove the entire head for the repair? What repair kits are available for that?
Best regards.
Marco
Post03-03-2005, 19:11    Subject: AFN, spark plug, stripped threads, help!!! Quote
Ouuuuuh, that's crap.
Normally, the spark plug needs to be removed completely to properly clean out any remaining carbon deposits. Is the cylinder now leaking past the spark plug threads? If not, and the spark plug is still functioning, try to leave it alone if possible. Otherwise, I would first try using a lot of compressed air (through the injector bore) on the corresponding cylinder, along with pliers. If the spark plug is intact but the threads are damaged, you can try removing it by pulling and twisting simultaneously. Then, obtain a Helicoil repair kit and cut a new thread using compressed air. It's better to remove the entire head.
EDIT: When replacing spark plugs on a Mercedes-Benz Vito, you may be required to sign a document stating that you will be responsible for the cost of removing the cylinder head if a spark plug breaks off during removal. It seems to be normal for Mercedes-Benz.
Avatar-Jan6K
Post03-03-2005, 19:25    Subject: AFN, spark plug, stripped threads, help!!! Quote
If everything else is still working properly and the spark plug is already broken, I would probably leave it as is, because the TDI engine will still start with three working spark plugs - most of the time, it will even start without any spark plugs. While it's partly a makeshift solution, the effort required for the alternatives isn't insignificant either.
The only question is whether the emission values can still be met, because the afterglow has a significant impact on those values.
Jan.
1Z5 CFHF / AHB H4D
Marco
Post03-03-2005, 19:29    Subject: AFN, spark plug, stripped threads, help!!! Quote
Well, who drives to the TÜV (technical inspection) with a cold engine? Regardless, the engine will be brought to operating temperature before the inspection. So, it's really a matter of conscience. I would answer with 'It doesn't matter.'
qwert1
Post03-03-2005, 19:55    Subject: AFN, spark plug, stripped threads, help!!! Quote
Okay, so the bulb is still inside, and you can wiggle it back and forth. The top part (the contact) is already broken off. So, I guess I'll have to take the head off. Damn!
Is the head clamped when drilling, because when using a hand drill, it doesn't drill straight, does it?
Best regards.
qwert1
Post03-03-2005, 20:21    Subject: AFN, spark plug, stripped threads, help!!! Quote
Do you need a torque wrench for the camshaft sprocket?
icon_question.gif or does it go down like that?
Best regards.
Marco
Post03-03-2005, 20:31    Subject: AFN, spark plug, stripped threads, help!!! Quote
Okay, don't give up just yet. Is the candle still firmly connected to the candle holder's threads? If so, see the instructions above. If not, you might be able to grip the threaded housing with pliers and twist it out. You don't need a puller for the NW hub; a regular copper dowel or something similar will suffice.
qwert1
Post03-03-2005, 20:45    Subject: AFN, spark plug, stripped threads, help!!! Quote
Does the NW (presumably referring to a component) not sit on a cone?
Marco
Post03-03-2005, 21:05    Subject: AFN, spark plug, stripped threads, help!!! Quote
Hello qwert1,
A little bit of self-initiative from your side would be appreciated. Please provide the German text you would like me to translate into English. I will then provide only the translation, without any explanations.
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Glühkerze bei Ausbau an AFN abgerissen [erledigt] Diesel Engine Technology
No new posts Thread for oil pressure gauge? Diesel Engine Technology
No new posts TDI T3 Bus: Warm Start Problem - Solution Code 00011 On-Board Diagnostics (OBD)
No new posts TDI AEL: Rough Idle - Fix & Troubleshooting Diesel Engine Technology
