Joined: 04/12/2002 Posts: 18142 Karma: +807 / -0 Location: St.Gallen 2018 Volkswagen T6
10-03-2005, 14:24 Subject: MKB, AHW, AKQ, APE: Documenting Clicking Noises |
Author: Michael II
Knocking sounds after a cold start.
As the engine warms up, the noise becomes quieter.
Cause:
In some cases, damage to the coating on the piston rod can lead to cold seizures.
Up to engine number:
AHW 186 532
AKQ 249 690
APE 056 974
Solution:
If distinct knocking sounds are detected coming from the engine immediately after a cold start, the following steps should be taken:
- Check the oil level and oil pressure.
- If the oil level and oil pressure are normal, notify product support.
Please provide the text you would like me to translate from German to English.
Bye.
Michael.
Translated on 14-10-2026, 23:43.
