General information about PD testing for troubleshooting idle problems... (Articles)
Warning: Undefined variable $rating_max in /var/www/community/includes/functions_rate.php on line 1191
🔗 ⭐ 🖨 Dieselschrauber - Index » Troubleshooting & Guides
vagtuning Post27-06-2005, 17:32
To check the PD unit values using VCDS in the engine control unit:
- Read error codes, and if necessary, clear or address them.
- MWB 001 Field 2 (Target: 3.0 - 9.0 mg/h) - TURN OFF AIR CONDITIONING !!
- MWB 004 Field 4 (-3 to +3 kW - allowable fluctuation of 0.5 kW)
- Check MWB 007 temperature readings for accuracy (cold vehicle with outside temperature).
- MWB 013 values fluctuating between -3.0 and +3.0 mg/H.
(if one or more fixed MWB 1 devices are present, with a flow rate less than 3 mg/h)
MWB 023 -100 is +100 (note that values from -60 or +60 should be considered).
(If values are greater than -60, suspect a fuel supply problem.)
(Values > +60 indicate poor fuel quality or a stuck injector.)
Furthermore, you should examine the values of the idle speed control in the measurement data.
 File size:  31.35 KB
 Viewed:  2880 times
Ratings - General information about PD testing for troubleshooting idle problems...
Average rating: 5.00 - worst rating: 5 - best rating: 5 - number of ratings: 2 - View ratings
No new posts General Audi customization channels Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Refrigerant Oil: Info and Details Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Some information about the longlife service Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A4 B6 Network Control Unit Malfunction? Is a test possible? On-Board Diagnostics (OBD)
No new posts TDI Engine Conversion for VW T3: Info & Docs Diesel Engine Technology
No new posts Transponder Immobilizer: Info & Details On-Board Diagnostics (OBD)
No new posts Golf Tiptronic: Info & Steering Wheel Paddles Diesel Engine Technology
