c8644
05-03-2005, 17:53 Subject: Is this true for Audi quattro? |
"I recently became the proud owner of an A6 Avant quattro TT5. In a moment of overconfidence during a recent trip, I drove the front wheels into a snowdrift. I put the car in reverse and tried to drive out, but I thought the quattro system and electronic differential wouldn't be a problem. However, I noticed that the rear wheels briefly started to spin, but when the front wheels lost traction, no power was being transmitted to the rear wheels. I then deactivated the ESP, but the problem persisted."
Okay, I have some questions about the quattro all-wheel drive system.
-How is the power distributed between the front and rear axles? Is it normal for the rear wheels to stop spinning completely?
-How does an electronic differential work, and does it affect the front wheels?
-What does the ESP actually do, or when does it intervene?
Translated on 20-10-2026, 5:58.
christians Profi-Schrauber
05-03-2005, 23:18 Subject: Is this true for Audi quattro? |
The current Quattros have EDS (Electronic Differential Lock) on both the front and rear axles, which means that a spinning wheel can be braked so that the other wheel on the same axle can maintain traction.
Between the front and rear axles, there is no conventional differential, but rather a Torsen differential, which does not have a brake-based locking mechanism but inherently exhibits a certain degree of "self-locking." To transfer power to the rear axle, as I understand from some posts on meckisforum.de, a significant amount of wheel spin is required on the front axle.
"True lockable differentials were only available up to the Type 44 or V8 models."
Gruß Christian
Translated on 20-10-2026, 6:00.
Steffarn Profi-Schrauber
07-03-2005, 8:42 Subject: Is this true for Audi quattro? |
Sure, because the all-wheel drive isn't permanently engaged like it was in the older Audi 100.
The Haldex coupling only engages the all-wheel drive system once the front wheels start to spin. However, this should happen very quickly, so that the driver doesn't really notice that the vehicle doesn't have a permanent all-wheel drive system.
It occasionally happens that the clutch malfunctions, which can then cause the front-wheel drive to lose traction, especially when cornering.
B.Eng (FH) u. KFZ Meister
Translated on 20-10-2026, 6:01.
Profile PM Email Garage |
faz Blaumann
1994 Audi 80 Premium Support
07-03-2005, 11:59 Subject: Is this true for Audi quattro? |
The A6 (with the engine mounted longitudinally) does not have a Haldex clutch, but rather a Torsen differential.
Torsen - Torque Sensing.
"Torque-sensitive"
MfG faz
Audi 80 B4 Avant TDi 10/93
Translated on 20-10-2026, 6:02.
Profile PM Garage |
syncro peter Guest
11-03-2005, 21:09 Subject: Is this true for Audi quattro? |
hello
I have edited my original post because, upon rereading it later, I realized that it was somewhat unclear.
First, let's look at the differences.
automatic locks
- viscous coupling
- torsen differential
externally controlled locks
- example Haldex
Important: TORSEN.
The Torsen differential has a torque-dependent locking effect, not a speed-dependent one, and is controlled by friction elements on the pinion gears.
Problem: If there is little or no traction with the ground, or if a wheel is off the ground, the forward motion collapses. In this specific case, the all-wheel drive turns into front-wheel drive, and there is no way to drive out of the snow, even if the electronic stability program (ESP) is active on the front wheels.
It's okay if the rear axle doesn't generate propulsion.
EDS controls the braking intervention until there is almost no difference in speed between the wheels of an axle, and torque can be transferred to the road.
peter
I like it better now.
Translated on 20-10-2026, 6:04.
Troubleshooter Guest
15-03-2005, 9:07 Subject: Is this true for Audi quattro? |
hello
Problem: If there is insufficient or very little traction with the ground, or if a wheel is off the ground, the forward motion collapses. In this specific case, the all-wheel drive system reverts to front-wheel drive, and there is no way to drive out of the snow, even if the electronic stability program (ESP) is active at the front.
peter
Are you sure about that? Doesn't that contradict the Quattro principle somewhat?
After reading that, I put our A6 TT5 on a lift and tried to hold the rear wheels in place (with three people) -> no success. Even though the front wheels were completely free to spin (and spinning quite a bit), a significant amount of force was being transmitted to the rear.
Even my 4motion  is that smart.
Translated on 20-10-2026, 6:06.
dieter Profi-Schrauber
Joined: 01/27/2003 Posts: 270 Karma: +13 / -0 Location: LK Uelzen
15-03-2005, 10:55 Subject: Is this true for Audi quattro? |
"Here's a quote from www.torsen.com:"
Quote: | Was passiert, wenn ich ein Rad in der Luft habe?
As mentioned above, the Torsen differential is a torque multiplier. The Torsen requires some type of resistance or friction in the system to function properly. A wheel in the air provides zero torque or friction on the system, and as the Torsen multiplies the available torque, zero, by its TBR, the end result is still zero. In response to this, we developed the Torsen T-2R with pre-load to combat those wheel in the air situations. |
It pretty much says it all, doesn't it?
That's why I'm also a fan of my viscous coupling, because in that case, it completely locks and transfers 100% of the power to the axle that still has grip.
Greetings.
dieter
T3 syncro 16 AFN
Translated on 20-10-2026, 6:09.
wolfi_b Profi-Schrauber
15-03-2005, 11:35 Subject: Is this true for Audi quattro? |
What if you simply brake slightly while reversing? Wouldn't that also cause some torque to be transferred to the rear wheels?
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 20-10-2026, 6:10.
syncro peter Guest
15-03-2005, 11:59 Subject: Is this true for Audi quattro? |
@dieter
Visco isn't bad, but it's pretty useless in the sand.
@wolfi
Why would that happen?
peter
15-03-2005, 12:47 Subject: Is this true for Audi quattro? |
| Was bedeutet das Drehmoment-Bias-Verhältnis?
Torque bias ratio (TBR) represents the "locking effect" of the differential. More specifically, it indicates how much more torque is sent to the high traction wheel (or axle) than is sent to the spinning wheel. For example, when a differential has a TBR of 3:1, 3 times the torque the spinning wheel can maintain (75% of the total torque) will go to the higher traction wheel. If a wheel is spinning and can support 100 lb-ft, the other wheel will get 300 lb-ft. |
Okay, if no torque is transmitted to the front wheels (because the wheels are slipping), then no torque is transmitted to the rear either (0 * x = 0).
What I was thinking was:
When you apply the brakes, a sudden torque is transferred forward, and consequently, also backward. In the example above, the rear wheels receive three times the torque of the front wheels, which should easily be enough to overcome the braking force of the rear brakes.
However, it's all just speculation, and it's possible that I'm thinking in the wrong direction...
1993 Audi 80 B4 1Z
Translated on 20-10-2026, 6:12.
matthiasTDI96 Profi-Schrauber
15-03-2005, 13:05 Subject: Is this true for Audi quattro? |
Specifically, our TDI engines (and likely other engine control units) detect simultaneous operation of the accelerator and brake pedals as a misuse and reduce the fuel injection amount.
Translated on 20-10-2026, 6:13.
syncro peter Guest
15-03-2005, 14:16 Subject: Is this true for Audi quattro? |
When you brake, suddenly torque is transmitted forward, and consequently, also backward.
I don't understand what you mean, sorry.
peter
Translated on 20-10-2026, 6:14.
Werner-TDM Guest
15-03-2005, 17:18 Subject: Is this true for Audi quattro? |
Hello Peter,
Just for trying out.
Brake with the left foot and accelerate with the right.
Normally, when the brake pedal is pressed, a signal is sent to the engine control unit (ECU). This then causes the engine to decelerate or reduce the amount of fuel injected.
Sure, here's the translation:
'Hello'
Werner.
Translated on 20-10-2026, 6:15.
syncro peter Guest
15-03-2005, 18:12 Subject: Is this true for Audi quattro? |
@werner
Now you're not understanding me  . What you're writing, I already understand. The statement from Wolfi, which I also quoted, I don't understand. I don't know what he's trying to say. I don't think he means the same thing as we do. But he will probably get in touch.
peter
rinderwahnsinn Guest
16-03-2005, 7:49 Subject: Is this true for Audi quattro? |
A Torsen differential is torque-sensing. This means that it locks when a difference in torque occurs and distributes the torque according to its torque bias ratio (TBR) value.
However, if one wheel spins freely, the torque-sensing differential cannot transmit any torque to the other side. A spinning or airborne wheel has virtually zero torque. 0 * TBR = 0. The vehicle will stop.
The same thing happens in a Quattro system when, for example, one wheel spins on ice.
Visco and Haldex systems offer clear advantages in this regard, or alternatively, mechanical locking differentials.
Slightly braking can sometimes help because the differential then has to transmit a significant amount of torque again, and this also causes the previously unpowered wheel to receive torque. This works on a sheet of ice, but not in off-road conditions.
CU.
Translated on 20-10-2026, 6:17.
16-03-2005, 10:33 Subject: Is this true for Audi quattro? |
Yes, exactly, that's what I meant.
1993 Audi 80 B4 1Z
Translated on 20-10-2026, 6:19.
