Light vibration between 3000 and 4000 RPM! HELP! SOLUTION!
MTM A6 2,5 TDI
Post10-04-2005, 13:55    Subject: Light vibration between 3000 and 4000 RPM! HELP! SOLUTION! Quote
After much deliberation and a vacation spent in the workshop, the problem is finally resolved. icon_cool.gif
The cause of the rattling was the output from the STG's mass flow meter!! 'Furthermore, the diesel pump was replaced at the same time, as its fuel injection control system was also no longer functioning optimally due to the high mileage, although this did not necessarily affect the rough running issue.'
If you're at a loss with your diesel engine and need a reliable service provider in the Nuremberg area, please contact me via private message. Here, you will receive fair assistance and not be ripped off like some repair shops that carry out fault diagnosis by random principle icon_wink.gif
Best regards
MTM A6 2,5 TDI
Post10-04-2005, 14:04    Subject: Light vibration between 3000 and 4000 RPM! HELP! SOLUTION! Quote
Ah, one more thing I forgot to mention: the fault at the LMM signal output was 99% due to a high voltage issue when the new side part was being installed by the mechanic, as they hadn't disconnected the battery and ECU during the welding process!! icon_evil.gif
Therefore, it also explains why the LMM was also defective after the accident repair...
Such an incident should serve as a reminder of how much trust one can place in a trusted business partner. icon_rolleyes.gif
Best regards
No new posts Durchzugsrechner / Leistungstest 2000 - 4000 rpm Technical Articles
No new posts Doku 2,5 l, 6-Zyl. / Ruckeln Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Ruckeln BPW im A4 (TDI 8V) DPF: Beschreibung und Behebung Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Leichtes Ruckeln zwischen 3000 und 4000 U/min Hilfe!!! Diesel Engine Technology
No new posts Leichtes Ruckeln, nicht motorbedingt! Transmission, Chassis, Body & Interior
No new posts Leichtes Ruckeln bzw. wellenförmige Beschleunigung Diesel Engine Technology
No new posts ATD: Slight vibration @constant 1000-1500 RPM Diesel Engine Technology
