Wiper Arm G3 with MFA - Part Number
togu
Post07-04-2005, 22:45    Subject: Wiper Arm G3 with MFA - Part Number Quote
I have a windshield wiper lever for a Volkswagen Golf III with Multifunction Display (MFA) here. However, the part number is slightly confusing me.
1H6 953 503 AB
I can't reconcile this number with the parts program.
Perhaps someone can help me figure out if the gear lever is correct for a 1996 Volkswagen Golf Mk3?
Thank you in advance!
togu
 Bild vom Hebel
 File size:  17.86 KB
 Viewed:  806 times
Translated on 26-07-2026, 9:38.
Post08-04-2005, 13:04    Subject: Wiper Arm G3 with MFA - Part Number Quote
In the G3, there are essentially two different types of steering column switches (excluding the MFA/GRA and rear wiper functionalities).
There are two types: one with a combined steering column switch where the turn signal and wiper levers are integrated into a single unit (found in older models), and another where the levers are separate.
If the multi-function steering wheel and rear wiper functions are compatible, and you have the same model (whether the controls are separate from the turn signal lever or integrated with it), then it should fit.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It refers to a sudden and strong gust of wind.
Translated on 26-07-2026, 9:39.
No new posts Explanation of the VAG part number Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB ASV: STG Part Numbers & Identification Diesel Engine Technology
No new posts Pump Connector Part Number: Find Yours Now! Diesel Engine Technology
No new posts Find Part Number: Search & Locate Easily Transmission, Chassis, Body & Interior
No new posts Pressure Relief Valve Part Numbers Diesel Engine Technology
