LMM Connector: 6-Pin to 5-Pin Adapter Conversion
Intze Georg
Post16-08-2002, 9:21    Subject: LMM Connector: 6-Pin to 5-Pin Adapter Conversion Quote
Hello.
I have a problem. I want to install a mass airflow sensor from a newer vehicle with a rectangular connector and 5 pins into my VW, but I have the old one with the round connector and 6 pins, and I don't know how the pin assignments correspond.
Please help me.
Best regards, Georg.
Translated on 27-07-2026, 11:15.
Post16-08-2002, 15:31    Subject: Easy weight loss: Does it really work? Quote
Hi.
Here's the occupancy information according to my records (without guarantee).
Function: Old connector (6-pin) to new connector (5-pin).
+5 Volts - 1 - 4
icon_smile_thumb_up.gif2 Volts - 3 - 2
Vehicle weight - 5 - not required.
Donation amount - 2 - 3
LMM signal - 6 - 5
Good luck; hopefully the new LLM will work well with the old control unit.
Translated on 27-07-2026, 11:17.
No new posts LMM for 1Z: Refurbished & Optimized:-) Diesel Engine Technology
No new posts Alten Poti Mengenstellwerk zerlegen Diesel Engine Technology
No new posts LMM Connector: Types, Wiring & Troubleshooting On-Board Diagnostics (OBD)
No new posts LDA Connector: Installation & Guide Diesel Engine Technology
