VTG Adjustment After Long Idle Time
Klausel
Post09-07-2004, 22:45    Subject: VTG Adjustment After Long Idle Time Quote
Hello!
"On my Golf III AFN, the VTG adjustment was..."
Anlassen beobachtet. Beim ersten Mal (nach 45 Min. (Exposure time)
It reached its maximum level in two phases, each representing half of the total movement.
immediately, while the other one took a short time. In the following attempts...
She quickly moved to the final position in a single, fluid motion.
Is it possible that the vacuum gradually decreases over time due to a leak?
and then only becomes available again after several more rotations?
Or is this already a sign of intermittent stuttering?
Greetings,
Klaus.
Translated on 21-10-2026, 22:05.
Post10-07-2004, 10:03    Subject: VTG Adjustment After Long Idle Time Quote
Of course, there can be many causes, ranging from a disconnected vacuum hose to a worn vacuum pump, a faulty solenoid valve for turbocharger control, or even a mechanical jam. However, you should be able to rule out the latter by manually operating the system.
That's not normal.
Translated on 21-10-2026, 22:06.
No new posts A2 Radio: Won't Turn On After Parking? (8Z0) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VTG Adjustment for VAG TDI Engines Technical Articles
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASZ No Start: Troubleshooting & Repair (Video) Diesel Engine Technology
No new posts Coolant Leak After Highway Driving Diesel Engine Technology
No new posts Clutch Hard to Engage After Driving Diesel Engine Technology
No new posts T4 ACV: Smoking After Standing - Troubleshooting. Diesel Engine Technology
