Accelerator Pedal Damper
robertf
Post23-05-2005, 14:33    Subject: Accelerator Pedal Damper Quote
What should you do if you get the impression that the engine feels less responsive to accelerator pedal movements after maintenance at the workshop compared to before?
I only found a mention in the forum about disconnecting the clutch pedal connector for this issue. If you do that, the engine reacts unfiltered to movements of the accelerator pedal. However, I didn't want to resort to such drastic measures right away, and you probably have to remove quite a bit of trim to get to the connector. It's too much effort for me just to test it.
Does anyone know (I unfortunately don't have a VAG-COM), whether there is a parameter in the engine control unit for the damping value, and whether it can be adjusted via VAG diagnostics? Perhaps someone has messed around with it, and now no one knows what happened... icon_rolleyes.gif
Thank you very much for your help!
Robert.
Translated on 07-08-2026, 13:23.
Rudi
Post23-05-2005, 14:44    Subject: Accelerator Pedal Damper Quote
It is helpful for anyone who wants to assist you if you include at least the vehicle type and engine code (MKB, which can be found on the engine block, production data plate, or other vehicle documents) in your signature (-> profile).
Rudi
Translated on 07-08-2026, 13:25.
robertf
Post23-05-2005, 20:03    Subject: Best German Coffee: Buy Online & Enjoy! Quote
Hello Rudi,
hast recht, habe ich jetzt nachgeholt. Sorry again!
Robert.
hb2000
Post24-05-2005, 8:57    Subject: Accelerator Pedal Damper Quote
If you disconnect the switch on the clutch pedal, the GRA (presumably a system or feature) will also be disabled, unless you bypass the switch. However, this is not recommended.
Translated on 07-08-2026, 13:26.
Rudi
Post24-05-2005, 9:05    Subject: Accelerator Pedal Damper Quote
Hello Robert,
Basically, your engine control unit might already be flashable (you should check that).
(Post the part number) and could (if Oettinger hasn't taken any precautions).
received a software update during a service at a VAG dealership.
with which the tuning would be ruined.
Rudi
Translated on 07-08-2026, 13:27.
frebert
Post24-05-2005, 17:23    Subject: Accelerator Pedal Damper Quote
What exactly did they do at the workshop? That information would be helpful! Maybe they replaced the timing belt or the fuel injectors?
Greetings.
Franz.
1,9 l AFN mit Schick Wasser LLK im T3
Translated on 07-08-2026, 13:28.
robertf
Post24-05-2005, 18:59    Subject: Accelerator Pedal Damper Quote
At the workshop, they only performed a regular minor service and adjusted the alignment.
I was actually only wondering if there's a parameter for adjusting the damping, similar to how you can calibrate the fuel level sensor or the fuel consumption display.
Can someone confirm that the value is permanently coded into the control unit and cannot be accidentally changed when plugging in a diagnostic tool?
Best regards.
Robert.
Translated on 07-08-2026, 13:29.
Post24-05-2005, 21:41    Subject: Accelerator Pedal Damper Quote
robertf wrote:
Can someone confirm that the value is permanently coded into the control unit and cannot be accidentally changed when plugging in the diagnostic tool?
To the best of my knowledge, that is the case.
To modify the "pedal response," a diagnostic tool is not sufficient; you need to resort to chip tuning.
Translated on 07-08-2026, 13:30.
ObenbeiMutti
Post25-05-2005, 18:25    Subject: Accelerator Pedal Damper Quote
Regarding the decadent (ML CDI) car owned by my father, it's generally possible to modify it with a tuning box using a laptop and a skilled tuner. The tuner then asks: 'How is the tuning box performing? Do you want a little more power? Should we make the accelerator pedal a bit more sensitive?'
I don't know how Ottinger or Volkswagen (VW) solve that problem.
Translated on 07-08-2026, 13:31.
robertf
Post26-05-2005, 12:52    Subject: Accelerator Pedal Damper Quote
Ok, dann weiß ich Bescheid! Thank you all!
Robert.
Translated on 07-08-2026, 13:32.
No new posts Document A2 8Z0 MJ 2002, The radio displays "Transport" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts "Rain Shield" by No Touch: Practical Test General Tips
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat Engine Codes AVF & EYF - Parts & Info Diesel Engine Technology
No new posts Euro 4 requirement not as "absolute" as previously thought? Diesel Engine Technology
No new posts Injector Nozzles: Can You Repair the "Tips"? Diesel Engine Technology
No new posts RNS315 Upgrade: Install "Discover Media" Now! Electrical Systems, Vehicle Electronics, Multimedia
