Exhaust manifold AEL. Can we use the 2-part one from 10V?
audi-quat
Post10-05-2005, 16:53    Subject: Exhaust manifold AEL. Can we use the 2-part one from 10V? Quote
My AEL has a damaged (between cylinder 4 and 5) exhaust manifold! At eblöd, you can buy a replacement, but after 150,000 km, my manifold is already broken. Therefore, I don't want to buy a used exhaust manifold, but a new one, specifically the 2-piece manifold for the 200 10V (used until 89). This manifold is supposed to be much better and fits any 10V gasoline engine (WR, MB, etc.).
Does the 2-piece exhaust manifold fit the AEL?
Best regards, Rob
TDII
Post10-05-2005, 23:40    Subject: Exhaust manifold AEL. Can we use the 2-part one from 10V? Quote
The 2-piece manifold comes from KG, MC, or JY. So, the hole image should already fit, but:
1. The channels of the 10V Otto turbines are much larger! Therefore, it results in poor transitions from the head to the valve.
2. The flange of the external wastegate must be closed, or alternatively, the AGR pipe would like to be connected there.
3. The turbocharger flange should not fit. Changing KKK26 to KKK14, and if it doesn't sit perfectly in the same place, I'm looking at a bad situation for the hose.
But that would be interesting!
Holger
audi-quat
Post11-05-2005, 16:06    Subject: Exhaust manifold AEL. Can we use the 2-part one from 10V? Quote
Hello Holger,
THANK YOU for your quick response! The idea is dead...
Best regards, Rob
No new posts Frage an die Profis : Kann ich diesen Luftfilter nehmen? Diesel Engine Technology
No new posts Kann man einen belibigen LLK nehmen? Golf 3 1.9td Bj.92 55kW Diesel Engine Technology
No new posts Exhaust manifold Diesel Engine Technology
No new posts Exhaust manifold repeatedly leaking Diesel Engine Technology
