Blower Relay J323 - Replacement & Parts
chaerte
Post11-05-2005, 11:58    Subject: Blower Relay J323 - Replacement & Parts Quote
My AFB engine is showing this error code when I read the diagnostic memory:
Error code: 1028
Relay for blower motor - Open circuit/short circuit to ground.
I've installed this in a boat, so I don't need a blower anywhere. However, I'm annoyed by the error - even though it doesn't seem like a big problem...
What relay is that supposed to be? When I check the wiring diagrams, I can't find anything. It's not listed for the radiator fan, the air conditioning system, or as an input signal to the control unit. It's also not listed as a relay with that designation in the Etos system.
Translated on 28-09-2026, 13:35.
chaerte
Post11-05-2005, 21:12    Subject: Blower Relay J323 - Replacement & Parts Quote
Habs gefunden, ist tatsächlich das Relais für die Lüfteransteuerung und wird über das Motorsteuergerät gesteuert.. Das hat aber im Stromlaufplan eine andere Bezeichnung (J397). Waruwhatever it may be...
Translated on 28-09-2026, 13:36.
Mephisto
Karma: +14 / -1   Thank you, like it!
Post12-05-2005, 8:06    Subject: Blower Relay J323 - Replacement & Parts Quote
You could "emulate" the relay using a resistor.
"Micha"
Translated on 28-09-2026, 13:37.
chaerte
Post12-05-2005, 15:04    Subject: Blower Relay J323 - Replacement & Parts Quote
Yes, I was thinking the same thing. I have some nice power resistors that should be perfect for that.
No new posts Engine and instruments fail - Relay 109? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts P068A Error: Engine Won't Start (Relay J271) Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Auxiliary Relay for Blower & AC Control in Parking He... Electrical Systems, Vehicle Electronics, Multimedia
No new posts Auxiliary Heater VW T4 Fan Rear Transmission, Chassis, Body & Interior
No new posts 3B5: Troubleshooting and Common Issues On-Board Diagnostics (OBD)
No new posts Blower Resistor for VW Polo 9N Transmission, Chassis, Body & Interior
