AFN TCU: Automatic & Manual Transmission Control
qwert1
Karma-Bildequivalent
Karma: +6 / -24   Thank you, like it!
Post08-03-2005, 0:56    Subject: AFN TCU: Automatic & Manual Transmission Control Quote
hello,
I would like to know if the same engine control unit (ECU) is used for the TDI AFN 81 kW engine in the third-generation Golf, whether it's a manual or an automatic transmission. Or are there differences?
Translated on 30-09-2026, 12:10.
Post08-03-2005, 8:42    Subject: AFN TCU: Automatic & Manual Transmission Control Quote
The control unit is the same, but the coding is different.
Translated on 30-09-2026, 12:11.
Post08-03-2005, 9:05    Subject: AFN TCU: Automatic & Manual Transmission Control Quote
hello qwert
Just put everything in one post. That's probably more sensible.
qwert1
Post11-05-2005, 18:53    Subject: AFN TCU: Automatic & Manual Transmission Control Quote
thank you
qwert1
Post11-05-2005, 18:55    Subject: AFN TCU: Automatic & Manual Transmission Control Quote
Yes!
No new posts Gear oil change T6 manual transmission Troubleshooting & Guides
No new posts Document: Flange, Wave, Gearbox 012 and 01A Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Automatic Transmission Problems: Audi A4 01N AFN General Tips
This topic is locked, you cannot edit or reply. Automatic Transmission Control Module Coding AFN On-Board Diagnostics (OBD)
No new posts Audi S5 8T, 4.2L Manual Transmission, ACC Coding On-Board Diagnostics (OBD)
No new posts Engine control unit cannot be coded for manual transmission On-Board Diagnostics (OBD)
No new posts Automatic Transmission Problems Diesel Engine Technology
