ECU Pinout: Wiring Diagrams and Information
Kool-Cat
Post03-06-2005, 4:45    Subject: ECU Pinout: Wiring Diagrams and Information Quote
I could use your help again!
Does anyone know the pinout for control unit number 038 906 019 AJ?
I need the pins for the K-line and L-line.
1.9 PD engine, MBK: ATJ, first registration 06/2000.
Best regards, Hannes.
Translated on 02-10-2026, 9:11.
Rudi
Post03-06-2005, 7:23    Subject: ECU Pinout: Wiring Diagrams and Information Quote
Hello Hannes,
Without wanting to offend you...
L-Line has not been available for TDI engine control units for approximately 10 years.
Are you sure about what you're planning to do icon_question.gif?
Otherwise:
Mass: 4 and 5.
12 Volt: 2
Ignition: 37
K-Line: 16
Rudi
Translated on 02-10-2026, 9:13.
Kool-Cat
Post04-06-2005, 5:46    Subject: ECU Pinout: Wiring Diagrams and Information Quote
Hello Rudi,
Thank you for your reply.
However, I'm a bit confused now, because according to my wiring diagram, I have...
Section 16: The W-clamp.
Translated on 02-10-2026, 9:14.
Rudi
Post04-06-2005, 9:35    Subject: ECU Pinout: Wiring Diagrams and Information Quote
It's the K-Line! In some cases, the MSTG is connected to the WFS-STG via the K-Line.
Diagnostic socket. Perhaps this is why VAG labeled the contact point with 'W'.
Rudi
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts { Diesel Engine Technology
No new posts PIN Assignment Comfort Control Unit On-Board Diagnostics (OBD)
No new posts 12V Socket Wiring: Pinout and Connections Diesel Engine Technology
No new posts PIN Layout Comparison: 1Z Engine Control Units On-Board Diagnostics (OBD)
