Drum Brake Squeal: Causes & Fixes
golf3schrauber
Post09-06-2005, 16:57    Subject: Drum Brake Squeal: Causes & Fixes Quote
The TÜV (German technical inspection agency) found a problem with the braking performance on the right rear of my Golf. As a result, I replaced the brake pads, wheel cylinders, and wheel bearings on both sides.
The brake cylinder on the original side was still the first one and, as a result, very rusty and leaking.
The first two weeks, everything worked well. The braking performance during the technical inspection (TÜV) was also satisfactory.
Now, the rear right brake is squealing when I brake.
I'm not talking about the typical short squeal you hear when releasing the brakes, which is common in VWs. I'm familiar with that problem.
The brakes squeal when braking, and quite loudly. However, it only happens just before the car comes to a complete stop. If you brake harder, the squealing stops.
If you apply the handbrake when the car is squealing, the noise stops.
I would like to fix this again, but I have no idea what's causing it.
In my search, I found something that suggests replacing the brake pads when dealing with low-frequency vibrations.
Mine are new, though.
Are there perhaps different ones?
Gruss Oliver.
GolfIII,1Z,66KW,von94 mit 500tKm !
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 20-09-2026, 14:35.
Mati
Post10-06-2005, 1:04    Subject: Drum Brake Squeal: Causes & Fixes Quote
If the handbrake cables are not properly adjusted (too loose), they will rub against the anchor plates.
Greetings.
Mati.
Translated on 20-09-2026, 14:37.
golf3schrauber
Post10-06-2005, 7:05    Subject: Drum Brake Squeal: Causes & Fixes Quote
And that's why you get that loud squealing noise when you brake?
I hadn't thought of that possibility yet. However, it might work, since I loosened the cables a bit after replacing the pads.
So, are the cables supposed to keep the brake slightly engaged, providing some tension?
Thanks for the tip, I'll adjust the cables this weekend.
Gruss Oliver.
Translated on 20-09-2026, 14:38.
golf3schrauber
Post11-06-2005, 15:46    Subject: Drum Brake Squeal: Causes & Fixes Quote
I've tightened the cable tension a bit more, but it's still squeaking.
With a few strong braking maneuvers, I was able to reduce the squealing, but it's not completely gone yet.
Does anyone else have any ideas?
Gruss Oliver.
Mati
Post12-06-2005, 1:50    Subject: Drum Brake Squeal: Causes & Fixes Quote
Then it's probably really the pads.
Did you install accessories or original parts?
Greetings.
Mati.
Translated on 20-09-2026, 14:39.
golf3schrauber
Post12-06-2005, 15:29    Subject: Drum Brake Squeal: Causes & Fixes Quote
The brake pads are from VW.
Part number: 1H0 698 520.
During assembly, I noticed that the new linings had a much lighter color than the previous ones, which were considerably darker.
If it's really the tires, why is only one side having problems?
Gruss Oliver.
Translated on 20-09-2026, 14:40.
LZ
Post12-06-2005, 20:37    Subject: Drum Brake Squeal: Causes & Fixes Quote
Hey, did you also replace the brake drum??? You're only talking about the wheel bearings! Personally, I always replace the drum as well when the bearings are worn out. It's usually pretty worn anyway, and I think that's probably the reason for the squealing in your case.
Best regards, Robert.
Translated on 20-09-2026, 14:41.
No new posts Doku Caddy 9K bis 04/96, Trommelbremse macht Geräusche Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3B 4Motion - sehr schwammig, bricht beim bremsen aus Transmission, Chassis, Body & Interior
No new posts Drum brakes on my Polo 9N3 are driving me crazy! Transmission, Chassis, Body & Interior
No new posts quitscht furchbar Transmission, Chassis, Body & Interior
No new posts Kann Russ im Kat / Filter (Pass.35i) die Leistung bremsen? Diesel Engine Technology
