cksIT Blaumann
Joined: 05/22/2004 Posts: 399 Karma: +18 / -0 Location: Riedstadt
08-07-2005, 12:06 Subject: long 5th gear on asd |
I've found the old thread, but there's nothing about a longer gear for the asd gearbox inside...
Was about a longer one, if so, what gear and part number?
Thank you in advance. Man muss es nicht brauchen, aber man muss es haben!
08-07-2005, 13:24 Subject: long 5th gear on asd |
Be happy, at least you have ASD.
My CTN (for the combo) is significantly shorter.
The CYP from AFN is longer.
That's not correct, Correction see below!!!
Look:
http://www.dieselschrauber.de/GKB.htmlTransparency, Teamwork
Profile PM Garage |
Frank A. Blaumann
2000 Volkswagen Golf Free account, no CAN development support
08-07-2005, 15:44 Subject: long 5th gear on asd |
@ dieselmartin Are you sure you helped him? The CYP is not longer than the ASD...
@ cksIT
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
* **5th gear**
02A 311 361 AM; 02A 311 158 AF = 28/40 = 0.7
02D 311 361; 02D 311 158 = 32/47 = 0.681
02Z311158A; 02Z311361A = 27/41 = 0,658 (here, the spring of the gear mounting must be modified)
I, however, assume no liability...
Best regards, Frank '00 G4 ALH 170tkm , 11mm Pumpe, GGU-Getriebe
Profile PM Garage |
cksIT Blaumann
12-07-2005, 6:40 Subject: long 5th gear on asd |
ok, danke
I need to get my control unit repaired first, and then I'll take a look. But I'm already itching to get started. Man muss es nicht brauchen, aber man muss es haben!
12-07-2005, 10:57 Subject: long 5th gear on asd |
Then the table is incorrect!
ASD Axis: 60:19
ASD 5th: 33:46
CYP Axis: 60:19 (same)
CYP 5ter: 29:39
So, zumindest anders, nämlich 3,65 %
m; Transparency, Teamwork
Profile PM Garage |
12-07-2005, 11:01 Subject: long 5th gear on asd |
Here's the comparison: ASD(normal G3)-CTN(Variant)
Profile PM Garage |
Frank A. Blaumann
12-07-2005, 13:22 Subject: long 5th gear on asd |
I don't know what you want with your CTN, the man has an ASD gearbox and wants to make it longer.
The table is correct, and for you, I will also write the beginning of the sentence from above until the end: The CYP is not longer than the ASD but SHORTER (the exact translation you have already found out).
Profile PM Garage |
12-07-2005, 13:50 Subject: long 5th gear on asd |
Hello Frank
Even though I initially felt a bit foolish, I've found my calculation error.
I was looking at the teeth of the first garden too much.
ASD, CTN and CYP have a 60:19 gear ratio.
The fifth is:
CTN 34:45 = 0.7555
ASD 33:46 = 0.714
CYP 29:39 = 0.744
So, we definitely have an order (in the mathematical sense) CTN -> CYP -> ASD
Is the ASD already the longest 02A gearbox?
Profile PM Garage |
Frank A. Blaumann
12-07-2005, 14:12 Subject: long 5th gear on asd |
Hello Martin,
to annoy you a little more: 33:46 is 0.717. (yes, I know it was just a trick)
Yes, I believe it's the longest standard combination. The longer 5th gears from other gearboxes, see above.
Best regards, Frank
P.S. I apologize if my tone came across as harsh, however, I also found your first response to the original question to be somewhat pointless (At least you have ASD, so be grateful). My CTN (for the combo) is significantly shorter. '00 G4 ALH 170tkm , 11mm Pumpe, GGU-Getriebe
Profile PM Garage |
cksIT Blaumann
14-07-2005, 13:31 Subject: long 5th gear on asd |
Sorry, I didn't have the email notification turned on.
so, wenn ich das richtig verstanden habe, es gibt keine längeren Gänge serienmäßig...
What about the ones mentioned above, can they be easily installed? Man muss es nicht brauchen, aber man muss es haben!
