Golf 3 TDI Synchro: Glow Plug Light On While Driving
brush.at
Post26-10-2005, 10:31    Subject: Golf 3 TDI Synchro: Glow Plug Light On While Driving Quote
Hello!
"For the past two days, the preheating light has been illuminated on my Golf 3 while I'm driving."
Is everything normal? (regarding starting/driving?)
Does anyone know about this?
Tunningaufkleber,T-Shirt Beschriftung mit Flock und Stick ! bei brush.at
Translated on 27-09-2026, 22:35.
Back to top Profile PM Email
Post26-10-2005, 10:50    Subject: Golf 3 TDI Synchro: Glow Plug Light On While Driving Quote
Tip: Read the error codes and use the search function here.
Rudi
Post26-10-2005, 10:56    Subject: Golf 3 TDI Synchro: Glow Plug Light On While Driving Quote
@brush
Please re-calibrate the pressure sensor pedals.
Rudi
Translated on 27-09-2026, 22:36.
Post26-10-2005, 12:41    Subject: Golf 3 TDI Synchro: Glow Plug Light On While Driving Quote
For understanding.
The yellow lamp with the glow plug symbol doesn't actually indicate the preheating process in TDIs anymore.
It is, rather, a general motor control indicator light.
Later, after about 200 uses, the MIL (Motor Indicator Light - something in English) also came on.
If a "1Z" indicator light illuminates while driving, it means something is not working correctly.
Post26-10-2005, 14:39    Subject: Golf 3 TDI Synchro: Glow Plug Light On While Driving Quote
dieselmartin wrote:
After 200x, the MIL (Motor something_in_english Lamp) came on.
By the way: that thing is called the Malfunction Indicator Lamp, IIRC icon_wink.gif.
Translated on 27-09-2026, 22:37.
Post26-10-2005, 14:43    Subject: Golf 3 TDI Synchro: Glow Plug Light On While Driving Quote
Really? What a great term.
It's good that "Lamp" is still in the name, because otherwise I would have thought it was a sheep.
Which "malfunction" is the lamp indicating?
*I'm already starting to get annoyed again about marketing naming conventions.*
Translated on 27-09-2026, 22:38.
vagtuning
Post26-10-2005, 17:42    Subject: Golf 3 TDI Synchro: Glow Plug Light On While Driving Quote
It indicates a malfunction of a component in the engine that is being monitored by the self-diagnosis system.
It could also be related to the ABS (Anti-lock Braking System), so it's advisable to check the engine and ABS systems, evaluate any error codes, and then take appropriate action.
Translated on 27-09-2026, 22:39.
No new posts Golf 1J ABS Light: Repair Guide & Troubleshooting Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
This topic is locked, you cannot edit or reply. Oil stain under the car - transmission fluid or brake fluid? General Tips
No new posts Document 1J, ESP Control indicator is lit up. Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Water Damage ASZ: Causes & Prevention Diesel Engine Technology
No new posts Red LED on door lock always lit, VW Golf 3 Electrical Systems, Vehicle Electronics, Multimedia
No new posts 1.8T engine with high mileage, what oil should I use? Gasoline Engine Technology
No new posts Heating Oil: Does It Work? (SEO Optimized) Diesel Engine Technology
