22-06-2005, 10:21 Subject: ABS Sensor: Troubleshooting & Repair Guide |
I have a static error code of 00285 on the front right sensor of my Ibiza 6K GP01 (the sensors are 1J0, like in the Golf 3/4).
Before we buy a new sensor, I wanted to test whether the problem is with the sensor itself or with the cable.
What voltage should arrive at the terminal?
What resistance should the sensor have?
Are there any guidelines or benchmarks?
Thank you.
Okay, please provide the German text you would like me to translate into English. I will only provide the translation. Transparency, Teamwork
Translated on 28-07-2026, 22:31.
Profile PM Garage |
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2403 Karma: +441 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
22-06-2005, 12:08 Subject: ABS sensor or cable problem? |
Hi Martin,
dieselmartin wrote: | | Before we buy a new sensor, I wanted to measure whether it's the sensor or the cable that's causing the problem. |
I would bet you 1:10 right now that it's not the cable. Most often, the sensor is dirty, misaligned (if possible with that model), or defective. Alternatively, the encoder disc could be bent or torn. (EDIT: With the G3, it was directly on the drive shaft, so the last option is ruled out).
dieselmartin wrote: | | What voltage should be present at the terminal? |
Unfortunately, I cannot answer that question.
dieselmartin wrote: | | What resistance should the sensor have? |
Since it operates inductively, you should ideally be able to measure capacitance rather than resistance. This capacitance should then change depending on the wheel position.
I would first visually inspect the sensor and clean the "teeth" of the drive shaft. If metal dust or rust has accumulated there, the capacitive measurement principle will no longer work. If that doesn't solve the problem, I would replace the sensor without further measurements. Other errors are extremely rare.
Sure.
Here is the translation of the text from German to English:
"Guste" means "gust" in English. It can also be used as a verb, meaning "to gust."
Translated on 28-07-2026, 22:34.
Profile PM Garage |
22-06-2005, 12:23 Subject: ABS sensor or cable problem? |
guste100 wrote: |
Since it operates inductively, you should be able to measure capacitance rather than resistance as much as possible. This capacitance should then change depending on the wheel position.
I would first visually inspect the sensor and clean the "teeth" of the drive shaft. If metal dust or rust has accumulated there, the capacitive measurement principle will no longer function.
Um... As far as I know, the sensors work inductively.
Then a resistance should be measurable (estimated freely from experience, somewhere in the kOhm range, 0 Ohms = defective, no continuity = also defective) .
As a reference, you can take one of the other 3 sensors .
Adjusting the wheel alignment changes the inductance, but to measure it, you would need a device like an LCR meter.
Capacitive sensors are sometimes used, for example, as steering angle sensors. I wouldn't expect to find them in an ABS system, though... |   Gruß Ulf
Translated on 28-07-2026, 22:37.
Profile PM Garage |
22-06-2005, 13:01 Subject: ABS Sensor: Troubleshooting & Repair Guide |
The target disc looked okay.
The error reappears immediately when the system is running normally.
As far as I could tell, because the thing is sitting on 17 aluminum rims and has been lowered (great for cornering, terrible for maintenance).
That's also why it's difficult to access other sensors (it doesn't fit on my ramps).
I was already considering connecting one of my sensors (located in the G3) using an extension cable. If the error then clears itself, it's likely the sensor that's causing the problem.
Well, I guess I'll just go ahead and install a new one – it's the money from my colleague  .
Translated on 28-07-2026, 22:40.
Profile PM Garage |
messknecht Blaumann
Joined: 06/09/2005 Posts: 29 Karma: +1 / -0 Location: Schwarmstedt
22-06-2005, 13:06 Subject: ABS Sensor: Troubleshooting & Repair Guide |
Hello!
ABS sensors typically have a coil resistance of approximately 1.2 kOhms, although this can vary depending on the manufacturer and may be as high as 1.8 kOhms.
The easiest way to measure the error is with an oscilloscope. With the ignition switched off, simply turn the crankshaft. You should see a smooth sine wave; the faster you turn it, the larger the amplitude. If you detect a signal when the ignition is on, it indicates test pulses that are monitoring the sensor.
I just read that errors often occur when things are running smoothly.
It's 99% likely to be the sensor because the wheel speed information is only queried while the vehicle is in motion. Gruß Messknecht!
Sharan 6.Gang BRT DPF
Mod.2008
Translated on 28-07-2026, 22:41.
22-06-2005, 14:33 Subject: ABS sensor or cable problem? |
ulf wrote: | guste100 wrote: |
I would first visually inspect the sensor and clean the "teeth" of the drive shaft. If metal dust or rust has accumulated there, the capacitive measurement principle will no longer function. . .
Oh dear, I seem to have written quite a confusing text. Of course, it is an inductive sensor and should therefore be testable using the methods you specified.
The Golf 3 also had a toothed wheel. My old Ford Scorpio's rear axle had the "teeth" on the driveshaft for the ABS system.
Therefore, only the general conclusion remains from my previous statement: It's either a faulty aperture plate or a sensor issue. The probability of another type of error is less than 10%. | |
Translated on 28-07-2026, 22:43.
Profile PM Garage |
22-06-2005, 15:19 Subject: ABS Sensor: Troubleshooting & Repair Guide |
Now I finally understand what was meant by "Zaehnen".
I had depicted it internally directly onto the holes of the perforated plate  , because I had already seen the perforated plate yesterday.
Translated on 28-07-2026, 22:45.
Profile PM Garage |
Martin R Guest
25-06-2005, 12:23 Subject: ABS sensor or cable problem? |
Here's a link to a thread I started.
http://www.doppel-wobber.de/wbb2/thread.php?threadid=1912
Translated on 28-07-2026, 22:46.
25-06-2005, 13:47 Subject: ABS sensor or cable problem? |
The link is only accessible to logged-in users with the appropriate permissions.
Profile PM Garage |
Martin R Guest
25-06-2005, 15:36 Subject: ABS sensor or cable problem? |
The link only works for logged-in users with the appropriate permissions...
Okay, that's why I just copied the content.
If the ABS warning light remains on, it is usually due to a problem with the speed sensors or the tone ring.
This can be checked as follows:
Measuring resistance.
- Disconnect the sensor and connect it to the two test leads of the measuring device, connecting each lead to one of the sensor's contacts.
Set point: approximately 1200-1800 Ohms.
- Connect one test lead to ground and the other to any of the sensor's terminals.
The target value should be in the megaohm range.
If both values are within the acceptable range, you should then check the signal.
Check the sender's signal.
- Jack up the vehicle (while ensuring it is securely supported to prevent rolling or falling).
- Reconnect the two test cables of the measuring device to the two contacts of the sensor.
- Set the measuring instrument to AC voltage (measurement range: 200 mV).
- Rotate the wheel, regardless of direction.
Set point: approximately 100 mV. However, it also depends on the speed (or RPM).
If no signal is received, the distance between the sensor and the toothed wheel may be too large, or the toothed wheel itself may be defective.
Read error codes.
Before starting any troubleshooting work, it's recommended to have the error codes read from the vehicle's computer so you can get an idea of where the problem might be located.
Note regarding target values.
The specified target values may vary slightly from vehicle to vehicle.
But the values should be almost identical for each axis.
Translated on 28-07-2026, 22:49.
