VW Passat 3b6 2.0 TDI (BGW) measuring blocks
Neues Thema 🔒 Gesperrt 🔗 ⭐ 🖹 Dieselschrauber - Übersicht » On-Board-Diagnose (OBD)
ormowiec
BeitrÀge: 4
Karma: +0 / -1   Danke, gefĂ€llt mir!
Beitrag09-09-2009, 13:15    Titel: VW Passat 3b6 2.0 TDI (BGW) measuring blocks Wird übersetzt...
At first, i'm sorry for writing in English - my knowledge of German is very poor (passing the anti-spam questions was real hardcore icon_biggrin.gif )
I'm looking for standard values of engine measuring blocks. Engine code BGW, VW passat variant 2.0 TDI, 2004 with DPF. I'm suspect PD's are dying (BIP's in 023 flirts up to 40)
Regards,
ORMO
Steffen W
BeitrÀge: 1276
Karma: +104 / -0   Danke, gefĂ€llt mir!
Beitrag09-09-2009, 19:25    Titel: VW Passat 3b6 2.0 TDI (BGW) measuring blocks Wird übersetzt...
standard values of engine measuring block MWB 23=
-100 to +100
Passat Variant BGW 2005
BeitrÀge: 17977
Karma: +781 / -0   Danke, gefĂ€llt mir!
Beitrag09-09-2009, 20:43    Titel: VW Passat 3b6 2.0 TDI (BGW) measuring blocks Wird übersetzt...
Just look in your VCDS label file...
ormowiec
BeitrÀge: 4
Beitrag10-09-2009, 8:37    Titel: VW Passat 3b6 2.0 TDI (BGW) measuring blocks Wird übersetzt...
At first, thanks for reply
I've got VCDS 805.4-PL and 908-EN and there is no label file for this engine icon_sad.gif
-100 to +100
Well, in fact i was looking for this block vals icon_smile.gif thank you very much. Are you shure BIP has such a big range in this motor? As far as I know, typical TDI-PD it amounts +-30
[Edit Admin: I think there is absolutely no need to link to some file hosters as the attachment function in this forum is inteded for this purpose.]
Best regards,
ORMO
one more question
004.4 = cam/crankshaft synchro, like in 1.9 TDI-PD?
Steffen W
BeitrÀge: 1276
Beitrag10-09-2009, 20:16    Titel: VW Passat 3b6 2.0 TDI (BGW) measuring blocks Wird übersetzt...
ormowiec hat folgendes geschrieben:
The name of the labe file is 038-906-016-BGW.lbl.Its in the "labels" directory.
And yes,iam sure +100 to -100.
ormowiec
BeitrÀge: 4
Beitrag11-09-2009, 7:46    Titel: VW Passat 3b6 2.0 TDI (BGW) measuring blocks Wird übersetzt...
Well, i'm shure there is no such file in my VCDS labels. Nothing with *BGW*
Dieses Thema ist gesperrt, Du kannst keine BeitrĂ€ge editieren oder beantworten. Passat 3BG 2005 TĂŒr öffnen Fehler und Dokumentation (Audi, VW, Seat/Cupra, Skoda)
Keine neuen BeitrÀge Standheizung in Passat 3BG einbauen Fehlersuche & Anleitungen
Keine neuen BeitrÀge Werkstattaktion Ladeluftschlauch, Passat B5, 74/96 KW Fehler und Dokumentation (Audi, VW, Seat/Cupra, Skoda)
Keine neuen BeitrÀge Passat 3B: Kat vom 110 PS TDI an den 115 PS PD TDI? Diesel Motorentechnik
Keine neuen BeitrÀge MFL Passat 3BG Bordnetze, Fahrzeugelektrik, Multimedia
Keine neuen BeitrÀge Log Passat v6 TDI Roh Upload
Keine neuen BeitrÀge Passat TDI BJ 2002 mit Eur 3 ?? Diesel Motorentechnik
Du kannst keine BeitrÀge in dieses Forum schreiben.
