Audi A6 Cold Start: Idle Speed Issues
mrfree
Post04-01-2007, 10:22    Subject: Audi A6 Cold Start: Idle Speed Issues Quote
When I start my Audi A6 (AEL, 1995) in the morning (cold start), the idle speed fluctuates between 1000 and 750 rpm, and it's difficult to start (it seems like only some cylinders are firing properly).
I tried with:
* double pre-heating (I'm not sure about this term in English icon_smile.gif)
* Adjusting the timing slightly higher than the standard values (using the VAGCOM TDI timing tool).
* accelerating slightly during startup.
But nothing seems to help icon_sad.gif.
Could this problem be related to G80 Implausible Signal (AEL)?
Sure, here's the translation:
"Thanks, in advance."
Translated on 17-10-2026, 14:55.
Post04-01-2007, 11:49    Subject: Audi A6 Cold Start: Idle Speed Issues Quote
Hi Laurento,
Are you sure all the glow plugs are working properly and heating up well?
Are the wires as easily accessible as they are in other TDIs? The 1Z model allows you to easily unplug the wire (it's actually a metal-rubber piece) simply by pulling it off the glow plugs.
If the AEL (Airbag Early Learning) system permits it, try to remove the spark plug and measure its resistance. It should be at 0.8 Ohms when the engine and spark plug are cold.
After 11 years, one or more spark plugs may fail, leading to cold start problems that typically only occur during the winter.
Translated on 17-10-2026, 14:57.
mrfree
Post04-01-2007, 11:57    Subject: Audi A6 Cold Start: Idle Speed Issues Quote
dieselmartin wrote:
Hi Laurento,
If the AEL (Automatic Engine Light) also allows this, try to remove it and measure the resistance of the spark plug. It should be at 0.8 Ohms for a cold engine and a cold spark plug.
After 11 years, one or more plugs may be dead, which results in cold start problems and occurs only during winter.
Many thanks for your reply icon_smile.gif.
I already checked them, but using a simple light bulb icon_rolleyes.gif.
I will check them tomorrow using a tester, and I will post the inspection result here icon_wink.gif.
Translated on 17-10-2026, 14:59.
mrfree
Post06-01-2007, 14:33    Subject: Audi A6 Cold Start: Idle Speed Issues Quote
For 4 plugs, the tester reports a resistance of 0.8 ohms, while for the remaining plug, it reports 0.7 ohms.
Sure, go ahead and run some more tests.
Translated on 17-10-2026, 15:00.
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Audi A3 Glow Plug Light Flashing: Help! On-Board Diagnostics (OBD)
No new posts AJM Performance Issues: Stuttering & Idle.log Analysis Upload
No new posts Bad cold start, lots of smoke Diesel Engine Technology
No new posts Audi 80 RS2 Steering Wheel Controls: Same as Audi A4 B5? Transmission, Chassis, Body & Interior
