Diesel Density: Temperature Effects & Chart
tim27
Post01-01-2003, 10:33    Subject: Diesel Density: Temperature Effects & Chart Quote
Hello everyone,
I once memorized the density of diesel fuel at various temperatures; I thought it might be interesting for those '10-cent tuning' projects.
Temperature (°C) | Pressure (bar) | Density (kg/m³)
0° 900 888
10° 900 882.5
20 900 876.9
50 900 860.3
80 900 843.7
100 900 832.6
If you manipulate the engine control unit to display a diesel temperature of 100° instead of 0°, it will likely inject approximately 8% more diesel fuel.
Can we also assume that approximately 8% more power can be achieved?
Translated on 23-10-2026, 7:37.
tim27
Post01-01-2003, 11:24    Subject: Explanation: A Simple Guide Quote
I think that's being portrayed in a somewhat negative light.
2. attempt.
0° (the first digit represents temperature), the second digit 900 represents the nozzle pressure in bar, and the third digit 888 represents the density in kg/m³.
I hope this is understandable.
Translated on 23-10-2026, 7:39.
diesel.gustav
Post01-01-2003, 13:00    Subject: SEO: Best Practices for Website Optimization Quote
Deleted upon request.
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Oil Temperature: How to Check & Fix Diesel Engine Technology
No new posts AFN Temp. Problem? On-Board Diagnostics (OBD)
No new posts Temp. Schalter - what for? Transmission, Chassis, Body & Interior
No new posts Coolant Temperature Fluctuations 1Z Diesel Engine Technology
