Does anyone know about error code P1649-35-00?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Glöckner Guido
Post22-02-2007, 20:01    Subject: Does anyone know about error code P1649-35-00? Quote
Please help, I'm still having problems with my VW Passat 3BG 4Motion TDI.
After approximately 40-60 kilometers, the warning light for the handbrake or brake still comes on.
I found this error today, but what does it actually mean?
18057
DATA BUS, drive error message, ABS control unit.
P1649-35-00
Can someone help me?
"Thank you."
Ihr Partner wenn es um Reifen geht.
www.Gloeckner-Motorsport.de
mullemaus
Post22-02-2007, 20:39    Subject: Does anyone know about error code P1649-35-00? Quote
Check the CAN-Bus connection from the ABS to the engine control unit and to the speedometer. icon_wink.gif
vagtuning
Post22-02-2007, 20:51    Subject: Does anyone know about error code P1649-35-00? Quote
Can you provide a little more detail about the vehicle?
What year is it, and what kind of TDI engine does it have?
Glöckner Guido
Post26-02-2007, 19:54    Subject: Does anyone know about error code P1649-35-00? Quote
Sure, here's the translation:
"So, it's a..."
VW Passat 1.9 TDI 130 hp All-wheel drive Sedan.
Year of manufacture: 2001, Model: 3BG.
I hope this helps.
vagtuning
Post26-02-2007, 20:12    Subject: Does anyone know about error code P1649-35-00? Quote
Self-diagnosis of the engine control unit: check data block 125, or ABS detected while stationary.
If everything is okay so far, then check if there's a '0' displayed when a message appears during communication, and see if you can still access the ABS system through diagnostics.
It's likely either a loose connection (intermittent fault) in the CAN bus wiring or a power failure to the ABS/ESP module. However, if that's the case, you wouldn't be able to access the self-diagnosis function at that moment either.
Glöckner Guido
Post27-02-2007, 19:59    Subject: Does anyone know about error code P1649-35-00? Quote
I checked the 125 mark, and everything is okay; it's a zero.
The ABS control unit is being accessed, but no errors are visible or can be read.
Do you have any more information about this error?
vagtuning
Post27-02-2007, 20:02    Subject: Does anyone know about error code P1649-35-00? Quote
If the ABS is accessible for diagnostic purposes, and the module shows a '0' indicating no communication, then you're in for a fun time troubleshooting the wiring.
Glöckner Guido
Post27-02-2007, 21:13    Subject: Does anyone know about error code P1649-35-00? Quote
Oh dear, please no. I hope he can be found.
I don't think it's a cable defect; I'm still hoping it's a problem with the circuit board.
mserge
Post28-02-2007, 13:05    Subject: Does anyone know about error code P1649-35-00? Quote
Most of the time, it's more likely a connector issue than a cable problem, unless it's something like a weasel causing damage, which you would be able to see from the outside.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
No new posts Disassembling the metering unit of a VP37 Troubleshooting & Guides
No new posts Function and components of an air conditioning system Technical Articles
No new posts Installation of an aftermarket seat heater Troubleshooting & Guides
No new posts Should injectors be replaced with these values? Diesel Engine Technology
No new posts What does the TÜV say about these brake lines? Transmission, Chassis, Body & Interior
No new posts Kann sich mal jemand diesen LOG anschauen? Diesel Engine Technology
No new posts Frage an die Profis : Kann ich diesen Luftfilter nehmen? Diesel Engine Technology
