The airbag warning light is illuminated. The airbag control unit displays the following error code: "65535 Control unit defective, intermittent error." The error cannot be cleared. This issue only affects control units that identify themselves as "Airbag Front and Side" in the self-diagnosis (part number 8L0 959 655 G).
Affected vehicle identification numbers:
Until 8LYA078299.
Cause:
Due to conceptual errors within the control unit, the control unit detects a closed micro-mechanical switch during system startup. However, because this is recognized as incorrect during the test procedure, the control unit stores the following error code: "65535 Control unit defective, intermittent error." This error cannot be cleared.
Solution:
Replacement of the control unit. The new control units have a data version from 2008. TschĂźss
Michael II
Translated on 11-10-2026, 20:39.
