dieter wrote: |
| The specific consumption is 230g/kWh. When the light is on, I need 400W more from the motor, which is 92g/h or 0.108 l/h more consumption. |
If you're actually achieving such a high engine efficiency in the real world, then your numbers are correct.
However, the balance looks different in column traffic: Low engine load -> lower efficiency. Let's cautiously say that the generator needs 0.15 liters of diesel per hour.
With an average speed of 50 km/h, you will consequently experience an additional fuel consumption of 0.3 liters per 100 km.
For a TDI car with an assumed fuel consumption of 6 liters per 100 kilometers, that would already be a 5% TFL surcharge.
For me, the TFL hype is just a billion-dollar business for the state (fuel taxes), oil companies, and profiteers, all disguised under the guise of road safety.
Anyone who fails to see a car without its lights on during the day, especially in an area with a high accident rate, is either so blind or distracted that they would also crash into a vehicle with its lights on...
