Adjustable Reverse Light Switch: Installation & Guide
rubberduck
Post23-03-2007, 10:02    Subject: Adjustable Reverse Light Switch: Installation & Guide Quote
Okay, so after I replaced the clutch on my Passat (1Z, cable-operated gearbox), the reversing lights stopped working. They function electrically. When shifting into reverse, you "overshoot" the activation point. The lights briefly turn on, and then they go off again when you properly engage the gear. I've already tried adjusting the linkage a bit, but without success. The gearbox functions perfectly and is well adjusted. Does anyone have any ideas or experiences with this?
Translated on 07-08-2026, 0:46.
Post23-03-2007, 10:23    Subject: Adjustable Reverse Light Switch: Installation & Guide Quote
There's a black plastic dome on the gearbox, about 5 German Marks in diameter (roughly equivalent to a coin), secured with two screws and featuring an electrical connection.
That's the switch.
You may have accidentally detached or loosened it while disassembling the transmission.
The part that is red.
 File size:  53.27 KB
 Viewed:  28760 times
Translated on 07-08-2026, 0:47.
No new posts Reverse Light Not Working? VW Golf IV Help! Transmission, Chassis, Body & Interior
No new posts A6 LL Service: Not Adjustable - Fix Now! On-Board Diagnostics (OBD)
No new posts Are new fuel injectors needed? Or adjustable? Diesel Engine Technology
No new posts Golf 3 Brakes: Adjustable BKV? Transmission, Chassis, Body & Interior
