AC Smells Bad: Troubleshooting & Fixes
oldewurtel
Post05-05-2007, 11:16    Subject: AC Smells Bad: Troubleshooting & Fixes Quote
Hello fellow enthusiasts,
It's happening to me too now - the air conditioner is stinking!
I have already read several articles about cleaning (e.g., Rainer K.'s reviews on Febreze and steam cleaners). I find them to be straightforward, informative, and reasonably priced.
Unfortunately, in my A4, the evaporator is not located directly beneath the cabin filter, so I don't have direct access to it.
Does that leave me with only the famous 'fog candle method' now (where a spraying aerosol can icon_eek.gif is placed inside the vehicle, and the car is run in recirculation mode for some time)?
Sincerely,
K. Oldewurtel
Translated on 21-08-2026, 5:55.
BM
Avatar-BM
Post05-05-2007, 15:18    Subject: AC Smells Bad: Troubleshooting & Fixes Quote
I am now left with only the famous "fog candle method"
There's also this kind of device that includes a long tube to reach inside the heating system. Sometimes, simply replacing the pollen filter might be enough.
3B5 AJM
Translated on 21-08-2026, 5:56.
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post05-05-2007, 21:13    Subject: AC Smells Bad: Troubleshooting & Fixes Quote
HI.
"I always buy a bottle of Sagrotan spray. Then, I remove the pollen filter, turn on the air conditioning to medium fan speed, and spray about half the bottle into the funnel. The car will smell like a doctor's office for a day, but afterwards, the odor is usually gone. It also helps to switch off the Climatronic 10 minutes before turning off the engine by setting it to ECON/off so that the evaporator can dry out. This prevents mold from forming quickly, which can cause a strange, musty smell."
"MFG" stands for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English. It is a common way to end a formal letter or email.
Audi SQ5 8R Cvub
Translated on 21-08-2026, 5:57.
Back to top Profile PM Email
oldewurtel
dieselschrauber likes this.
Post06-05-2007, 12:05    Subject: AC Smells Bad: Troubleshooting & Fixes Quote
Thank you for the answers.
I had also bought a can of Sagrotan spray and wanted to simply spray it into the intake side (where the pollen filter is located) while the fan was running. However, after reading the warning labels ('Highly flammable'), I decided not to do that.
I want to clean the vaporization surface and not explode it icon_eek.gif!
I then drove to the auto parts store and bought the air conditioning cleaner from Liqui Moly (for 17 euros!).
The part has a rather thin hose, approximately 50 cm long, which, despite its length, cannot pass through the fins of the fan blade in order to reach the evaporator directly icon_evil.gif.
You go through all that trouble just to clean the evaporator surface of bacteria, so let's get to work on the evaporator.
1.) Remove the glove compartment.
2.) Carefully drill two or more holes into the plastic housing (pay attention to the drilling depth!), as the atomizer sits at an angle inside the housing (see appendix).
3.) Spray the LM air purifier (Caution! The can will be empty in approximately 5-10 seconds, so distribute it evenly within that time icon_wink.gif).
4.) Seal holes with wide fabric tape.
5.) After 10 minutes of exposure, there is no more smell icon_idea.gif icon_idea.gif.
Probably, you could have used Sagrotan now icon_eek.gif, but in any case, I'm keeping the long, thin hose from the LM air purifier.
Kassen (the one with the now pleasantly smelling air conditioning).
 Explosionszeichnung vom Verdampfergehäuse. Man kann sehr schön die schräge Lage erkennen.
 File size:  21.25 KB
 Viewed:  24208 times
Translated on 21-08-2026, 6:00.
wolfi_b
Post06-05-2007, 19:18    Subject: AC Smells Bad: Troubleshooting & Fixes Quote
Why didn't you just remove the fan motor?
Drilling can be quite dangerous. A vaporizer like that is fairly expensive, and the installation requires a lot of work.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 21-08-2026, 6:03.
oldewurtel
Post07-05-2007, 17:04    Subject: AC Smells Bad: Troubleshooting & Fixes Quote
Hello Wolfi,
That was also my second thought (after the spraying caused by the fan blade).
I already had the TORX screwdriver in my hand, but it was a bit difficult to reach the top screw(s). Also, I have my speaker crossovers located in the upper area, and I would have had to disassemble quite a few things there.
In that case, the more straightforward method was to drill carefully.
Best regards, Cashiers.
Translated on 21-08-2026, 6:04.
No new posts Empty the air conditioner Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Air conditioner smells bad General Tips
No new posts Serpentine belt (drive belt) replacement for T6 TDI with ... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts AVF smells unpleasant Diesel Engine Technology
No new posts Exhaust Smells Like Water: Troubleshooting Guide Diesel Engine Technology
No new posts Air conditioner advice Transmission, Chassis, Body & Interior
No new posts Air Conditioner: Buy, Install & Repair Transmission, Chassis, Body & Interior
