AC Compressor Hose Replacement
Post22-06-2007, 19:31    Subject: AC Compressor Hose Replacement Quote
Hi.
Is that the control signal for the magnetic coupling?
The cables are rubbing against the air conditioning pipes, and one is almost completely worn through icon_sad.gif.
How do you do that again?
 File size:  145.06 KB
 Viewed:  5582 times
Translated on 28-08-2026, 19:00.
tdi pumpe düse
Post22-06-2007, 20:15    Subject: AC Compressor Hose Replacement Quote
Hi Martin, what kind of vehicle is that? I'm guessing it's not your Passat.
Translated on 28-08-2026, 19:01.
Post22-06-2007, 20:29    Subject: AC Compressor Hose Replacement Quote
NE.
It's a Leon 1M ASV, model year 2001.
Jochen_145
Post23-06-2007, 20:34    Subject: AC Compressor Hose Replacement Quote
Hello Martin,
Yes, that must be the clutch.
According to my records:
Brown/Black = Ground (GND)
Green/Black = Plus.
Best regards, Jochen.
Post25-06-2007, 8:23    Subject: AC Compressor Hose Replacement Quote
In the photo on the left, you can see that I temporarily wrapped some Panzer tape around it.
How do I replace the cable?
Because it disappears further up in the cable harness.
I thought I could simply replace the entire plug with a new one that has 2 wires, then solder it just behind the wiring harness, put a heat shrink tube over it, and that would be it.
Translated on 28-08-2026, 19:02.
Post25-06-2007, 8:40    Subject: AC Compressor Hose Replacement Quote
"If the cross-section is already starting to degrade, I would do it this way. Otherwise, I'll use heat shrink tubing and see if I can mitigate the wear point with a cable tie."
Translated on 28-08-2026, 19:03.
Post25-06-2007, 12:17    Subject: AC Compressor Hose Replacement Quote
The cross-section of the cable now only consists of two strands of the wire and a lot of green insulation material... so, "it's necessary" (or "it has to be").
No new posts Doku Golf 1J, Air conditioning compressor making noise Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts Generator free wheel defective - slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Cable Tuning: Optimize Your Car's Performance Diesel Engine Technology
No new posts OBD2 Cable: Connect & Diagnose Your Car Diesel Engine Technology
No new posts Cable differences Transmission, Chassis, Body & Interior
No new posts CAN Interface RKS+CAN & SUB-D9 Cable On-Board Diagnostics (OBD)
