Lupo 3L ABS Steuergerät umcodieren ? | Posts 16+
Go to page: Previous  1, 2
New Topic 🔒 Locked 🔗 ⭐ 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
vagtuning
Post30-05-2007, 17:29    Subject: Quote
Hmm, maybe it's worth having the engine control unit reprogrammed for a manual transmission; that might stop it from searching for the GSG (gear selector group).
Translated on 04-09-2026, 7:52.
Ross-Tech-Support
Post31-05-2007, 1:11    Subject: Quote
The engine control units (ECUs) that are typically used with 085 transmissions are usually already set to "manual transmission," which is another reason why I would prefer to post specific data (e.g., a vehicle scan) rather than continue to speculate. icon_smile.gif
pete121
Post26-07-2007, 18:06    Subject: Quote
Good evening.
Den Umbau habe ich soweit abgeschlossen. Das 1,2 Steuergerät habe ich ersetzt durch das 1,4 TDI-Steuergerät. Außerdem ist ein 1,7 SDI-Kombiinstrument reingekommen. Nun läßt sich der Motor natürlich nicht starten, weil die WFS mit den Neuigkeiten nicht harmoniert. Anstatt nun in die nächste Werkstatt zu fahren, um alles anzulernen, würde ich es gerne selbst machen. Dazu benötige ich ein Interface und die passende Software. VAG-CI already have OM.
Which interface would you recommend? Besides the initial setup, I want to upload a new tune to the MSG, as well as calibrate the built-in speedometer and also recalibrate two other speedometers that were removed from a Lupo. What other recommended software do I need?
Thank you for the specific help!
Peter.
Lupo 3L 1,2 TDI 419.000 km ANY 8/99
Prototyp-Getriebesteuergerät
Translated on 04-09-2026, 7:53.
mullemaus
Post26-07-2007, 18:29    Subject: Quote
Good evening.
Peter
We are not a speedometer adjustment forum, Peter. You won't get those kinds of answers here! icon_wink.gif
Translated on 04-09-2026, 7:54.
No new posts Documentation Lupo MKB AYZ, problems with driving behavior Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Occasional starting problems with the Lupo 1.4 TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Workshop Action: Software Adjustment, Gearbox, 3L Lupo Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Recode ECU: How to Reprogram Car Computer On-Board Diagnostics (OBD)
No new posts Recode engine control unit On-Board Diagnostics (OBD)
No new posts Recode Audi A6 4G GRA to 1 km/h Electrical Systems, Vehicle Electronics, Multimedia
No new posts Audi A8: Recode US Headlights (2005) On-Board Diagnostics (OBD)
