Replace intake manifold pressure sensor in the control unit?
Bastelfred
Karma: +6 / -4   Thank you, like it!
Post06-08-2007, 11:42    Subject: Replace intake manifold pressure sensor in the control unit? Quote
Can the intake manifold pressure sensor be replaced in the engine control unit (ECU) of an AFN engine? I have a part number from Bosch: 0 273 003 210, which is supposed to be a BOSCH 250 kPa MAP sensor. Is it essentially the same as the one in the ECU of the AFN engine? Can someone tell me something about it?
I'm having a problem where my device occasionally throws a "short circuit" error code.
Thomas
Post07-08-2007, 12:57    Subject: Replace intake manifold pressure sensor in the control unit? Quote
Yes, that is the correct MAP sensor.
You should be able to easily exchange it.
Thomas.
Audi S2 ADU Bj. 1993
Audi A3 TDI ASZ Bj. 2001
vagtuning
Post08-08-2007, 22:24    Subject: Replace intake manifold pressure sensor in the control unit? Quote
Does Bosch supply this as a replacement part?
And does VW/Ford only sell complete steering control units?
Bastelfred
Post10-08-2007, 10:22    Subject: Replace intake manifold pressure sensor in the control unit? Quote
Is it also available on eBay?
[EBucht Link]
Post10-08-2007, 12:15    Subject: Replace intake manifold pressure sensor in the control unit? Quote
... or here:
Okay, I will translate the text from the provided URL. However, I need the actual text content from that URL to perform the translation. Please provide the text from the webpage located at http://shop.dieselschrauber.de/product_info.php/products_id/291. Once you provide the text, I will give you the English translation.
Bastelfred
Post13-08-2007, 10:48    Subject: Replace intake manifold pressure sensor in the control unit? Quote
You could have mentioned that earlier. I ended up buying it somewhere else.
Post13-08-2007, 10:59    Subject: Replace intake manifold pressure sensor in the control unit? Quote
*g* You didn't ask me, but no worries, thanks for checking! Since I didn't think there would be a market for it, I didn't include it in the shop.
neubaupe
Post13-08-2007, 11:09    Subject: Replace intake manifold pressure sensor in the control unit? Quote
Hi!
Even though it probably doesn't happen very often, what do you do if you want to run an Audi, BMW, or Mercedes (AFN) engine with a turbocharger pressure exceeding 1.5 bar?
Best regards.
Peter.
Karma: +438 / -0   Thank you, like it!
Post13-08-2007, 11:18    Subject: Replace intake manifold pressure sensor in the control unit? Quote
neubaupe wrote:
...what do you do if you want to run an AFN with a boost pressure above 1.5 bar
Mount the 300kPa sensor and adjust the sensor characteristic curve accordingly. (But don't ask me for details, I'm afraid I'm not that familiar with the subject).
However, a significant number of adjustments would need to be made, both mechanically and in terms of software, for pressures exceeding 1.5 bar to be meaningful in the AFN system.
Guste.
No new posts Passat V157: How to Replace and Calibrate CBDC Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ABS Control Module 6X0 907 379B - Error Code 00668 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the engine control unit (ECU) for an Audi A4 B5... Gasoline Engine Technology
No new posts Replacing xenon ballast, Audi A3, but how? Transmission, Chassis, Body & Interior
No new posts pin compatible? - can I simply replace the message? - is ... On-Board Diagnostics (OBD)
No new posts Replacing the battery - larger size possible? Diesel Engine Technology
