Maße für Einstell- oder Arretierlineal füe Nockenwelle | Posts 16+
Go to page: Previous  1, 2
hueso
Post10-02-2003, 8:30    Subject: Quote
The ruler is very similar to the old one, it's just longer in the middle. Specifically, it has a 'nose'.
I will get the measurements if needed.
That would be great!
Post10-02-2003, 11:11    Subject: Tip zum Arretierdorn für die ESP Quote
CU-Heating pipe is available in 12, 15 (!) and 18mm outer diameter.
I don't remember exactly what fit for my 1.6D back then, but the ZR (timing belt) replacement is due for the TDI soon.
haehnlein
Post10-02-2003, 12:22    Subject: Quote
hueso wrote:
Where can I get a cheap camshaft holder (VAG 3036)?
Hi, if you can weld:
bend a piece of round steel into a horseshoe shape, with a steel extension at the back and two steel pieces at the front, orthogonal to the horseshoe level, ready. Can you bend it so that it fits into all the wheels (intermediate shaft, cam shaft etc.)?
I had the marking stake turned -> Diameter 15.45mm (TD, 1Z, AAZ, AFN)
Christian
Andy
Post10-02-2003, 12:23    Subject: Quote
... and in 22mm and in 28mm and...
But the 15mm pipe fits icon_biggrin.gif. I used it for a 1.6D once.
Best regards, Andy
haehnlein
Post10-02-2003, 16:02    Subject: Quote
...when using a locked latch, the fit accuracy is not really that important either. A long nut is also sufficient. The pin is only used to ensure that the number of teeth on the gearbox wheel and the ESP wheel match.
I also highly recommend the locking line from Klann. This is very accurate, and with all the camshafts I have used it on, the measurable clearance on both sides was constant (0.35mm per side, according to the feeler gauge measurement).
You can also drive the camshaft wheel with a key (through the hole in the rear cover) from the cone. However, I place the end of the mothering roller (->for the tension roller) in between, because the material of the cam wheel is very soft!
Christian
No new posts {ENGINE_TYPE} Dimensions and Wear Limits Technical Data
No new posts Dimensions GT17/BV43 Turbocharger Adapter Technical Data
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Camshaft Worn or Lifters? Metal in Oil Filter Diesel Engine Technology
No new posts Vacuum Hose Size: Dimensions & Specs Diesel Engine Technology
No new posts Exhaust gas recirculation (EGR) specifications for the AF... Diesel Engine Technology
No new posts ATD Nockenwelle OT Diesel Engine Technology
