Injection Volume Not Reached: Troubleshooting
tdigolf
Post06-01-2008, 11:25    Subject: Injection Volume Not Reached: Troubleshooting Quote
Hello.
I once read the sensor data during a drive and noticed that the target fuel injection amount was not being reached. The target value was 43, but the maximum value I was getting was 34.
That's probably why the car doesn't have much power. But what could be the reason for that?
Best regards, Christian.
Translated on 06-09-2026, 9:08.
Post06-01-2008, 11:39    Subject: Injection Volume Not Reached: Troubleshooting Quote
Here, it doesn't specify which engine it is, nor does it mention any quantity limits...
Translated on 06-09-2026, 9:09.
tdigolf
Post08-01-2008, 22:30    Subject: Injection Volume Not Reached: Troubleshooting Quote
The engine is a 1.9 TDI 1Z with 90 horsepower.
It's the fuel injection quantity limiter, or what do you think?
haithamina
Post09-01-2008, 9:35    Subject: Injection Volume Not Reached: Troubleshooting Quote
Hello tdigolf,
He's referring to which type of fuel injection quantity limitation you're talking about, based on torque, opacity (smoke), or driver demand. In the corresponding data block, these are listed side-by-side. In the acceleration phase of a production TDI, the fuel injection quantity is typically limited by torque, even if you want to inject an infinite amount of fuel via the accelerator pedal.
haithamina
Translated on 06-09-2026, 9:10.
mserge
Post09-01-2008, 15:28    Subject: Injection Volume Not Reached: Troubleshooting Quote
If the opacity reading has the lowest value, then you are effectively experiencing a loss of power. This is usually due to the mass airflow sensor.
It would be best if you could post your engine's data log (while running at full load in 3rd or 4th gear, at 3000 RPM), and then someone will be able to give you more specific information.
See you later.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
Translated on 06-09-2026, 9:11.
No new posts P0011 - Camshaft Timing Delayed: Not Reached Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Golf IV ATD PD - Unable to reach top speed - LOG Upload
No new posts LD Vacuum Leak: 890mbar Idle, No Pressure? Diesel Engine Technology
No new posts ARL Fails to Meet Lending Target Diesel Engine Technology
No new posts AGR Not Closing: LMM Value Never Reaches Target Diesel Engine Technology
