21-02-2008, 19:18 Subject: Can ABS only be deactivated when the vehicle is stationary? |
Today, I thought for a while that my ABS (ABS FRONT MK60 / 6Q0 907 379 L) was defective because I couldn't get it to disengage while driving, even though I was using VAGCOM (professional system, latest version purchased from this shop) -> "Control unit does not respond."
According to the MSG, the ABS was functioning normally on the (CAN) network, and no warning light was illuminated.
Once I got home, I tried it again (while standing still, engine off), and sure enough, the ABS could be opened immediately, and the warning lights could be read, etc.
Is this normal, or am I once again experiencing a level issue with the ABS on the K-line, causing the VAGCOM interface to fail to recognize the low-high transitions? Gruß Ulf
Profile PM Garage |
21-02-2008, 19:29 Subject: Can ABS only be deactivated when the vehicle is stationary? |
Hi Ulf,
It's probably normal that new connections to ABS control units can only be established when the vehicle is stationary. I've definitely experienced that before, on several occasions.
Profile PM WWW Garage |
21-02-2008, 22:17 Subject: Can ABS only be deactivated when the vehicle is stationary? |
My Golf3 wouldn't let me engage the manual stability control (MSTG) anymore, even starting from 100 km/h.
Therefore, it is conceivable.
It's not bad from a security perspective either.
m; Transparency, Teamwork
Profile PM Garage |
mullemaus Guest
21-02-2008, 22:20 Subject: Can ABS only be deactivated when the vehicle is stationary? |
The motor should stop communicating (establishing a connection) again at approximately 2000 RPM. The ABS system is usually always active while driving, and measurements typically stop around 20 km/h. So are my observations  .
22-02-2008, 7:24 Subject: Can ABS only be deactivated when the vehicle is stationary? |
mullemaus wrote: | ABS usually activates while driving, and measurements typically stop around ~20 km/h. Here are my observations  | . What's more, does the ABS only provide log data up to approximately 20 km/h?
Then the sensor check options using individual wheel speeds would be  . Gruß Ulf
Profile PM Garage |
wolfi_b Profi-Schrauber
22-02-2008, 8:00 Subject: Can ABS only be deactivated when the vehicle is stationary? |
Mine only goes up to about 8 km/h  . 1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
