27-02-2008, 16:27 Subject: Astra 2006: Read VC Unit Data |
Hi.
Can I use my CAN Profi VAGCOM to check if a 2006 Astra has ESP?
A friend thought she had, but that didn't stop her from getting off the train  .
m; Transparency, Teamwork
Translated on 24-09-2026, 19:48.
Profile PM Garage |
Aron Blaumann
Joined: 10/26/2006 Posts: 440 Karma: +5 / -1 Location: KC
27-02-2008, 17:08 Subject: Astra 2006: Read VC Data |
dieselmartin wrote: |
A friend thought she had, but nothing stopped her from getting off the train .
Hi Martin,
The warning light in the instrument cluster should provide information about this. Ultimately, the ESP system can only intervene to correct the vehicle's trajectory if the driver provides information about the intended steering angle. Depending on the ESP's sensitivity, it may only activate when there is already a significant amount of wheel slip, and in the case of inexperienced or overly aggressive drivers, it may not be able to prevent a loss of control or skidding. Peugeot 307 (T5)1450kg Speck, RHS, MJ2002, 138g CO2 inkl. Korken im Auspuff und goldene Möhre 2006, MAF+50% mit passender Dieselmasse. nunmehr 370000km
Translated on 24-09-2026, 19:49.
Profile PM WWW Garage |
matthiasTDI96 Profi-Schrauber
27-02-2008, 18:18 Subject: Astra 2006: Read VC Unit Data |
The thing about the control light is not correct. My Golf doesn't have ESP. When I press the ASR button, the same symbol appears as with ESP (VW seems to have saved on control lights there)...
Hopefully, she hasn't injured herself. Have you checked the ABS/ESP unit under the hood? What's the part number?
Translated on 24-09-2026, 19:51.
27-02-2008, 19:24 Subject: Astra 2006: Read VC Unit Data |
No, she was just lucky.
I'm quite confused that you were told the car had ESP, but you can't find any evidence of it, either in the car's features or otherwise.
I also read that it might be installed in the Astra H, but it cannot be deactivated.
But a 120 horsepower CDTI Astra GTC without ESP? I can't believe that.
Translated on 24-09-2026, 19:52.
Profile PM Garage |
27-02-2008, 20:37 Subject: Astra 2006: Read VC Unit Data |
Take a look at the letter; if it was imported from the EU like mine, it probably doesn't have ESP,  .
Deus Violentia Schrauber
28-02-2008, 23:05 Subject: Astra 2006: Read VC Unit Data |
How about simply calling an Opel authorized service center and having them check the vehicle's VIN through their system to see if it's listed in the vehicle's equipment list? It should be in there...
Translated on 24-09-2026, 19:53.
29-02-2008, 8:25 Subject: Astra 2006: Read VC Unit Data |
Hi.
Sure, that's possible, but...
(1) It's not my car.
(2) I trust my own work more than I trust service people who often seem unhelpful or uninterested.
(3) I sent it to the Opel dealer specifically for that reason.
Translated on 24-09-2026, 19:54.
Profile PM Garage |
obelix2054 Blaumann
Joined: 06/12/2007 Posts: 44 Karma: +3 / -0 Location: Meck. Pom.
29-02-2008, 11:12 Subject: Astra 2006: Read VC Unit Data |
Hello.
@ dieselmartin
If you send me the VIN number, I can check it in the EPC.
and send you the result.
It should at least list what was included from the factory and the subsequent modifications.
You also save  with this  .
Best regards, Obelix.
Translated on 24-09-2026, 19:55.
