Kühlflüssigkeitsverlust/ Geber für Regelkreis | Posts 16+
Go to page: Previous  1, 2
BM
Avatar-BM
Post08-05-2008, 22:46    Subject: Quote
Is there anything to consider when replacing the head gasket due to chip tuning, especially if the cylinder head needs to be machined? Due to the potential increase in compression? Or is this negligible?
"Up to 3/10 mm shouldn't be a problem. However, what would cause me concern is the condition of the pistons. They are prone to developing cracks, especially with modifications and aggressive driving. It's difficult to predict when this might happen (search function --> piston crack or piston split). Also, the connecting rod bearings are a weak point in this engine, particularly with overheating."
You need to consider what you plan to do with your vehicle and act accordingly.
3B5 AJM
Translated on 21-08-2026, 14:12.
No new posts P0404 - Exhaust Gas Recirculation (EGR) Control Circuit M... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero-tolerance for deviations in the steering angle of th... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Zero offset for accelerator pedal angle sensor (G85) in B... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts What kind of donor is this? Diesel Engine Technology
No new posts MAP sensor G71 Diesel Engine Technology
No new posts Faulty NOx Sensor 2: Causes & Fixes Diesel Engine Technology
No new posts G28 Encoder Position: Find & Troubleshoot Diesel Engine Technology
