Crack in windshield, what now?
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
bindpe
Karma: +5 / -2   Thank you, like it!
Post12-05-2008, 14:46    Subject: Crack in windshield, what now? Quote
Hello forum.
Yesterday, I noticed a crack in the lower left corner of my windshield. As I said, it starts from the left corner and is approximately 50 to 70 mm long. Only the outer layer of glass is affected.
What would you do? As far as I understand, can this [plant/animal/situation] no longer be saved? Should we just keep going until it grows bigger?
What is the cost of a windshield replacement including installation? Does anyone know of a good and affordable company in the Munich area?
Thank you for the answers?
Peter.
P.S.: If it's important to know, this is a GIII.
Golf III TDI AHU 402Tkm
Spritmonitor.de
Translated on 20-07-2026, 22:30.
Karma: +643 / -0   Thank you, like it!
Post12-05-2008, 17:05    Subject: Crack in windshield, what now? Quote
Hi.
Finding something affordable in the "M" area is likely difficult; with a budget of €400-€600 without including utilities, you'll probably be on the higher end of the price range.
I cancelled my health insurance years ago and used the money I saved to buy a high-quality cutting machine.
http://www.foerch.de/files/customized/foerch/productcatalog/28f44ccc-c29f-4127-8540-1420696e9bb7/thumbnails/image_4.jpg
It was bought for DM 800 back then, and it has already paid for itself many times over.
The windshield replacement on my last T4 cost me €95 and took 2 hours of labor.
Best regards, Rüdi.
Translated on 20-07-2026, 22:31.
golf3schrauber
Post13-05-2008, 12:46    Subject: Crack in windshield, what now? Quote
Is this a standard multi-tool with a special attachment, or is it a dedicated device designed solely for this purpose?
I have a multi-tool like that. You would only need the attachment for it.
Gruss Oliver.
GolfIII,1Z,66KW,von94 mit 500tKm !
Polo 6N,AEE,55KW, von 96
Audi A4 B7, BPP von 2006
Translated on 20-07-2026, 22:32.
teileklaus
Avatar-teileklaus
Karma: +12 / -0   Thank you, like it!
2005 Volkswagen
Post13-05-2008, 14:00    Subject: Crack in windshield, what now? Quote
The best way for me to separate them is using twisted golden (brass) wire.
It's inexpensive, doesn't scratch glass, won't break (knives are more expensive and fragile), and doesn't require electricity.
It needs an assistant, but you'll definitely need one to lift the disc anyway, unless it's a Fiat 500.
Gruß, der Teileklaus
Fiat 500, Einkaufswagen
Translated on 20-07-2026, 22:33.
Post13-05-2008, 19:21    Subject: Crack in windshield, what now? Quote
I have a multi-tool like that. You would only need the attachment.
Hi.
This isn't the budget-friendly Multimaster, but rather the precision cutter.
Best regards, Rüdi.
P.S. Knives are expensive, Teileklaus is right.
Translated on 20-07-2026, 22:34.
teileklaus
Avatar-teileklaus
2005 Volkswagen
Post14-05-2008, 8:53    Subject: Crack in windshield, what now? Quote
You shouldn't force it; if something isn't working, don't push too hard. But the device itself is good!
Translated on 20-07-2026, 22:35.
zocker100
Avatar-zocker100
Post22-05-2008, 19:51    Subject: Crack in windshield, what now? Quote
It got to me too.
First, a rock impact within the visible range.
Now I have another crack that starts from the bottom left and extends towards the center of the glass.
I'll continue as I am for now. Because the crack doesn't seem to be getting any bigger.
Most likely, a new windshield will be needed by the next scheduled inspection (TÜV).
Unfortunately, I don't have the expertise to replace the windshield myself.
Whether I am practically capable of doing it, I cannot say due to a lack of experience. icon_biggrin.gif
Let us cast a curse upon those evil, deeply embedded stones.
However, my record has generally seen its best days.
Driving 120,000 kilometers on the highway has definitely left some marks.
What is the general opinion of the "cheap" items offered on eBay?
Something like "Disc with installation: €199".
Are there different quality levels for windshields?
See you then.
Markus.
Audi A4 2,5l TDI Bj.04 MKB BDG 220.000km
Audi 80 B4 Avant 1,9l TDI MKB 1Z 242.000km. --> verkauft
Translated on 20-07-2026, 22:37.
Post22-05-2008, 20:10    Subject: Crack in windshield, what now? Quote
Above all, there are different quality levels for the installation itself... everything is crooked and misaligned, sealant is smeared everywhere, window frames (paint) are damaged during removal and not repaired, etc.
Translated on 20-07-2026, 22:39.
Post22-05-2008, 22:39    Subject: Crack in windshield, what now? Quote
"Above all, there are different quality levels for the installation itself... everything is crooked and misaligned, sealant is smeared everywhere, window frames (paint) are damaged during removal and not repaired, etc."
Greetings, Rainer
Unfortunately, this applies to many workshops as well. That's why I prefer to do it myself, and I take my time doing it.
"However, the quality of the windshields has really deteriorated, regardless of where they come from. That's why my original windshield is still in place after almost 400,000 kilometers."
Best regards, Rüdi.
Translated on 20-07-2026, 22:40.
Benni
Post23-05-2008, 12:01    Subject: Crack in windshield, what now? Quote
Greetings, Rainer
True words...
After replacing the windshield, there was 5 cm of water on the driver's side, the trim is dirty, and the dashboard is dirty.
Next time, then no more cheapskate behavior... icon_rolleyes.gif self-inflicted.
Translated on 20-07-2026, 22:42.
No new posts Resolution: "Crack in BKD cylinder head" Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Frontscheibe Transmission, Chassis, Body & Interior
No new posts Ventilation problems, windshield Transmission, Chassis, Body & Interior
No new posts Frontscheibe wechseln Transmission, Chassis, Body & Interior
No new posts Windshield manufacturing date Transmission, Chassis, Body & Interior
