AFN only accepts gas up to 1500 RPM after starting
35i-299
2004 Volkswagen Passat Consumption
Post12-06-2008, 21:30    Subject: AFN only accepts gas up to 1500 RPM after starting Quote
Hi...
Here's the problem:
After I converted my Passat 35i VR6 Syncro to a TDI Syncro, I'm experiencing the following problem.
After starting the engine, it only revs up to approximately 1500 RPM. I can press the accelerator pedal all the way down, but it stays at 1500 RPM. It only starts accelerating normally after I've completely let off the gas and then press the gas pedal again.
"The error memory indicates 'On-board voltage, terminal 30 - implausible signal'."
How can I fix this error, or is this entry even related to my problem? My friend has a Corrado TDI with the same issue. Only he doesn't have the "terminal 30" error.
The engine is a 96 AFN model with a GT1749VA turbocharger and 0.230 injectors. The software is genuine.
Best regards.
Sven.
96´Passat 35i TDI AFN Syncro
Umbau auf 4-Motion
04´Passat 3BG V6 TDI 4-Motion
DieselBär30x
Avatar-DieselBär30x
Post13-06-2008, 0:21    Subject: Re: AFN only accepts gas up to 1500 RPM after starting Quote
35i-299 wrote:
...I can then press the pedal all the way down, but it stays at 1500 revolutions. Only after I completely release the accelerator and then press it again does it normally respond to the gas...
Hi Sven!
If the MSG (Module for Steering and Gas) detects both brake pedal actuation (via the dual switch) and a driver load request greater than 0% (essentially, pressing the accelerator), then the phenomenon you described will occur.
Please check the (additional) wiring connected to the MSG (Modular Service Gateway) that was necessarily replaced on the TDI.
Best regards from Munich!
mserge
Post13-06-2008, 10:33    Subject: AFN only accepts gas up to 1500 RPM after starting Quote
You're absolutely right, my car does that when I press the brake and then the accelerator. It then runs at 1500 RPM and stays there. If I release the accelerator and press the brake again, it goes higher. Check the brake switch, wiring, and control unit, as mentioned before.
neuer Turbo bei 200.000km
neue ESP bei 216.000km
verkauft mit 225000tkm
Clio 2 RS 170 PS BJ2003
No new posts Engine won't start, cranks after start attempt Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Engine Idling Low: Troubleshooting & Repair Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts TDI No Power After Start - Troubleshooting Diesel Engine Technology
No new posts Engine Spin-Up After Start Diesel Engine Technology
No new posts Vibrations and white smoke after start, AAZ engine Diesel Engine Technology
No new posts G4 1.6 FSI knocking shortly after start? Gasoline Engine Technology
