ABS Light On: VW Transporter T4 Troubleshooting (Solution)
Michael II
Post18-03-2003, 12:33    Subject: ABS Light On: VW Transporter T4 Troubleshooting Quote
The ABS warning light is occasionally illuminating.
Affected vehicle identification numbers (VINs):
Up to 7D1 H 116 047.
Cause:
The affected vehicles are all T4 models equipped with the Electronic Stability Program (ESP) and featuring ignition switch part number 6N0 905 865.
Faulty CAN signal from the ABS-ESP control unit. After switching to the new ignition switch, error code 01435 "Sensor for brake pressure G 201 (ESP pressure sensor)" is occurring more frequently.
Solution:
Replace the ABS-ESP control unit.
Tschüss
Michael II
Translated on 13-08-2026, 19:12.
Ratings - ABS Light On: VW Transporter T4 Troubleshooting
No new posts Transporter 7D: Brake Pad Wear Light Always On Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D Clutch Problems: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Transporter 7D: Documentary about Whistling Noises Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N3: Oil pressure light flickers intermittently Diesel Engine Technology
No new posts Glow plug light illuminates intermittently with engine ru... Diesel Engine Technology
No new posts T6 Transporter, Noise Reduction Transmission, Chassis, Body & Interior
No new posts VW Transporter T4: Flashing Oil Pressure Light? Diesel Engine Technology
