Rear brake calipers, difference? Audi A3 8L, year of manufacture 1998->2002
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post13-06-2008, 18:12    Subject: Rear brake calipers, difference? Audi A3 8L, year of manufacture 1998->2002 Quote
Hello everyone,
I now have an Audi A3, type 8L, manufactured in 1998, with a 1.6 liter gasoline engine and 101 horsepower. It has been converted to run on LPG, and it is not equipped with all-wheel drive (4Motion).
Unfortunately, the rear brake calipers are completely worn out. I could get used ones from a good acquaintance for an Audi A3, type 8L, with a 130HP PD engine, manufactured in 2002, which is also not a 4Motion model.
After searching through well-known online retailers, I noticed that products were only available until the year 2000.
Can someone tell me what the differences are compared to the newer model, or are they compatible with each other?
Translated on 22-07-2026, 10:28.
vagtuning
Post13-06-2008, 19:18    Subject: Rear brake calipers, difference? Audi A3 8L, year of manufacture 1998->2002 Quote
The backing plates are the same, but the hand rests are different.
Translated on 22-07-2026, 10:30.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post15-06-2008, 13:06    Subject: Rear brake calipers, difference? Audi A3 8L, year of manufacture 1998->2002 Quote
I suspect that they were changed because of the constant icon_mad.gif.
vagtuning
Post15-06-2008, 13:09    Subject: Rear brake calipers, difference? Audi A3 8L, year of manufacture 1998->2002 Quote
Then one would expect that the old ones would be replaced by the new ones, but no, there are actually two different types, one for going up and one for going down.
No new posts Audi A3 Steering Wheel Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi Engine Codes: Types, MKB, GKB, AKB, MJ Technical Data
No new posts Audi Turbochargers: Differences Explained Diesel Engine Technology
No new posts Spark plug difference Audi 3.0 TDI 059 963 319E vs. J Diesel Engine Technology
This topic is locked, you cannot edit or reply. Fuel Injector Difference: T4 151PS vs. Audi AEL 140PS Diesel Engine Technology
No new posts ALH vs. AFN Engine: Differences and Specs Diesel Engine Technology
